So ive finially decided to upgrade the speakers in the 5
i bought some JL audio 6.5in splits (great sound for the 400 i paid, these retail at 799), and a Kicker 2 Chanel Amp.
Now the ideal place for the amp would be behind the passenger seat about half way up the firewall. That way the seat base can still go right back just with the recline a tad more upright. I tend to use my boot a fair bit and fill it right up, so id like to keep the boot space free.
I assume there are several people on here with the amp mounted in the said position. My main concern would be heat from the amp. Do you think there would be enough air circulation around the amp to stop it from overheating? How have other people come across this?
The amp wont be running at full power and also wont be powering a sub.
Any comments.
Cheers in advance
Amp Placement
- Regie
- Vehicle: NC - V8
Amp Placement
- Locutus
Amp Placement
if you're not going to run it at full power heat will never be a problem. mine is behind the driver's seat and only gets warm (~40C), never hot.
- Jeo
Amp Placement
I'm assuming NA/NB, in which case this should help.
I've currently got the brain box for my head unit mounted there and have no problems with it. When it first went in I made sure the seat back never touched it and checked it by hand every other drive, saw no problems with heat so pushed the seat all the way back. Continued monitoring it for about a fortnight and it seemed fine so I left it alone. Has been like that for 6-9months now and hasn't caused any concern.
Long story short, I wouldn't worry about it.
- Regie
- Vehicle: NC - V8
Amp Placement
yeah NB8B
ive read most of the topics in this section and yeah looks like i dont have to worry about it..
Bring on the sound i say!
- Kain
Amp Placement
Hey, that's my amp setup in the thread Jeo referenced. Just chiming in to say its been there a month now and I've had no heat issues at all.
Just be careful with the install and you'll be fine. Best of luck!
Amp Placement
- daffyflyer
Amp Placement
Pah.. Look at all that weight - Take that amp out or you'll make wun angry!
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
Amp Placement
Just takes 2 wing nuts and a few plugs and all that weight comes right out.
- daffyflyer
Amp Placement
Okibi wrote:Just takes 2 wing nuts and a few plugs and all that weight comes right out.
True true, but when you put it back in, I imagine Wun feels a disturbance in the force...
