Drivers side rear brake light broken
Oni
Postby Oni » Tue Mar 03, 2009 10:11 pm
Hi all :)
I was told today that my drivers side brake light isnt working, i pulled the bulb and it looked like it wasnt blown and it also goes on when i have the park lights on. I noticed its sort of 2 lights in one globe, i guess ones the parking light and the other is the brake to over power the parking one. I had a look at the wires going into the connection and they all had no movement in them so i dont think its a wiring thing but im not too sure. Just thinking about it i will try swapping in the bulb from the other side and see how that goes, it might be a blown globe but tricky to tell. Ive also checked the fuse and that was ok.
Sort of pointless post untill i can try swapping the bulbs lol ill report back tomorrow.
Fatty
Postby Fatty » Tue Mar 03, 2009 10:37 pm
removing the globe from the other side, and plugging it in would take about 30 seconds. how long did it take you to type this post??
Postby Mr Morlock » Thu Mar 05, 2009 12:21 pm
stop tail twin filament. A filament may be broken- inspect by eye. If the bulb is ok ( try the swap ) then check the brake light connector to see if it is live ( test light) when someone pushes the brake pedal down. You can buy a bulb at Bursons who seem to stock Philips which is likely to be a good product.
