Does anyone know if its possible to adjust the headlight from left to right and vice versa ?
If so how do you do it?
I know how to adjust it up and down but my P/S light needs to point more to the left
NB8A - Adjust Headlights
- TieNN89
All modern lights must have both adjustments by law. I do not have your model so not sure of exact location but usual is 2 bolts/screws with hex head and Philips drive.These should be visible when you pop the bonnet. Your handbook may tell you or local dealer. Best accurate method of headlamp adjustment is with a beam setter and many workshops have these and may do it very cheaply or sometimes gratis.
