Flashing Air Bag Light
TieNN89
Postby TieNN89 » Wed Feb 11, 2009 4:47 pm
Alright so my Airbag lights are flashing :(
Today it flashed all the way till I got home and still flashing
flashes 6 times then has a longer pause then flashes another 6 times ...
Got home turned the car off then back onto ON and the lights kept flashing so i took a video of it
Yesterday it flashed 6 times then has a longer pause but that stopped about 1min after on my way home
Anyone have any idea whats wrong with it?
How to fix?
Where to go? (Brisbane Preferred) How much its going to cost?
Thanks,
Tien
TieNN89
Postby TieNN89 » Wed Feb 11, 2009 5:43 pm
corners
Vehicle: ND - Supercharged
Postby corners » Wed Feb 11, 2009 6:58 pm
Have you tried resetting the ECU by removing the battery for a bit and reconnecting.
Otherwise there might be an error code in the ECU I cant remember which models have OBDC
TieNN89
Postby TieNN89 » Wed Feb 11, 2009 7:06 pm
yep the battery terminal is removed atm and i just cleaned the airbag connectors i know of (behind the glovebox) (behind the horn, and behind the steering wheel)
gona reconnect it all now and see how i go
it use to come on once in a while which started about a month ago but only recently has it been coming up more and more often
TieNN89
Postby TieNN89 » Wed Feb 11, 2009 9:03 pm
SWEEET
its gone i think
will see in a few weeks time
hopefully its fixed for good :D
TieNN89
Postby TieNN89 » Thu Feb 12, 2009 1:16 am
I have a similiar thread posted on the miata.net site
and a member replied with a link to this
http://www.miata.net/garage/airbag_blink.html
which means my D/S airbag was fault or poor connection...
hopefully its fixed :D
