NA Amp Placement
Kain
NA Amp Placement
Postby Kain » Thu Feb 05, 2009 8:15 pm
I'm trying to find a spot to install my amp in my '93 NA, to power my door speakers. I'm trying to avoid using the boot since there's no room in there already, and the extra wiring to and from the dash is going to be a pain.
I'm wanting to put it under passenger seat if I can, but it looks like there's bugger-all room underneath it. It's an Audison SRx 2, and its dimensions are 36x22x6cm. I'm going to try pulling the seat in the next few days and trying fitment that way, but if someone who already know's it won't fit can save me the trouble, that'd be appreciated :D
If that won't work, I'm thinking of mounting it behind the passenger seat instead. Is there anything behind that carpet I should be concerned about drilling into?
Thanks for the help guys.
NA Amp Placement
Postby Jeo » Thu Feb 05, 2009 8:54 pm
Not much room below the seat, particularly if you want to still be able to move it.
Plenty of room behind though.
Not 100% but I'm pretty sure the fuel tank lives between the seat and the boot, so probably not the best place to go drilling. I mounted the brain unit for my head unit there and simply attached it to the carpet with four little velcro tabs.
TieNN89
NA Amp Placement
Postby TieNN89 » Thu Feb 05, 2009 9:55 pm
I've got the Audison SRx3
bigger i assume
there bugger all room under my seats I'd guess its the same case with the NAs
Between your cabin and the boot is your fuel tank I wouldn't recommend doing it there unless you can see behind or feel or know for sure that you have enough room I'd suggest not to drill or screw there
Why not mount it in your boot?
Altho the NA boot is slightly different I believe heres my SRx3 in my NB boot
I painted the MDF black thinking of carpeting it now tho not that you can see much
xatz
NA Amp Placement
Postby xatz » Thu Feb 05, 2009 10:12 pm
You might be able to use the holes that the little plastic pins go into that hold the carpet on behind the seats. It's awfully close to the fuel tank though. I'd recommend taking that panel off to see what kind of clearance you can get on the other side of the holes. That'd be pretty adventurous though as you'd have to remove a lot of trimming to be able to remove that panel.
Is there any space under the dash near the glove box?
JD
Locutus
NA Amp Placement
Postby Locutus » Thu Feb 05, 2009 11:51 pm
velcro it to the carpet behind one of the seats as Jeo described. the previous owner did this in my car and it's quite effective and secure even tho it sounds pretty dodgy. i'm one of those electronics nuts who does everything properly and i haven't found a need to change the setup despite rewiring the whole setup.
Garry
NA Amp Placement
Postby Garry » Fri Feb 06, 2009 12:21 pm
ebola
NA Amp Placement
Postby ebola » Fri Feb 06, 2009 1:06 pm
I had the same problem and resigned myself to putting it in the boot attached to my sub box. Actually the sub box takes up the entire boot so I had to move the space saver behind my passenger seat. Oh and then there is the computer in the boot connected to the touch screen which is now in the dash running the GPS and music/video software I wrote... MP3 head units are so early 2000's hehehe
Also Have a look at putting some speakers on the parcel shelf. It helps a lot! I made up some speaker boxes with some round 6" PVC tubing, just Sealing the back and putting the hook side of the Velcro all over it so it sticks to the carpet. Works perfectly.
mx5cartalk n00b
Wakefield - 1:18.62 - Standard 1990 NA6
madboy
NA Amp Placement
Postby madboy » Fri Feb 06, 2009 2:47 pm
ebola wrote:Also Have a look at putting some speakers on the parcel shelf. It helps a lot! I made up some speaker boxes with some round 6" PVC tubing, just Sealing the back and putting the hook side of the Velcro all over it so it sticks to the carpet. Works perfectly.
I'd love to see pics of that
NA Amp Placement
Postby Jeo » Fri Feb 06, 2009 6:45 pm
I didn't loose too much boot space by doing this...
TieNN89
NA Amp Placement
Postby TieNN89 » Fri Feb 06, 2009 6:49 pm
Garry wrote:.
Fuzzlet
NA Amp Placement
Postby Fuzzlet » Sun Feb 08, 2009 10:25 pm
Jeo, Althought you havent lost too much boot 'space' with your amp placement, you probably wont be able to put things onto of it while using the amp for long periods....The amp I used to run in my NA (similar placement) melted its shape into the bottom of my work bag after a 10min drive to work....amp was running a sub mind you :wink:
NA Amp Placement
Postby Jeo » Sun Feb 08, 2009 11:16 pm
Fuzzlet wrote:Jeo, Althought you havent lost too much boot 'space' with your amp placement, you probably wont be able to put things onto of it while using the amp for long periods....The amp I used to run in my NA (similar placement) melted its shape into the bottom of my work bag after a 10min drive to work....amp was running a sub mind you :wink:
There was a good two week stint there where my car cover lived squashed in the boot all day every day, only coming out to go on the car at night. But even now I throw a large nike kit bag straight on top of the amp, twice a week for a 20 minute drive each way to and from training. I've thought about the heat a couple of times but haven't ever noticed anything.
What kind of amp were you running?
Mine is 4x150wrms, driving the front splits and an 8" sub.
Fuzzlet
NA Amp Placement
Postby Fuzzlet » Mon Feb 09, 2009 12:20 am
I was running a 2 x 100w amp bridged, powering a 10" sub. I had the gain turned a fair way up...On long drives the that amp would turn itself off because of heat. First time it did that I was thinking wtf, until I tried touching it...
NA Amp Placement
Postby Okibi » Mon Feb 09, 2009 12:49 am
Here's mine in the NB, only takes a minute to remove it for track days etc.
Now sure what i'm going to do with the NA, I still have a 407 from when I ran 4x 8"s in the NB and I have another one of these cheapie Clarion Amps.
ebola
NA Amp Placement
Postby ebola » Mon Feb 09, 2009 10:45 am
Hey Madboy, Here are the pix of My PVC Pipe Speaker Boxes. The car is in being resprayed so it is covered in dust. Also pics of the touchscreen, volume knob, and computer/Monitor on/off buttons...
Excuse if this didnt work correctly, this is my first attempt at a picture post on this forum. =)
mx5cartalk n00b
