Hello Everyone
Not sure if relay is a shelf item
other than at Mazda spare parts is there any where else i can purchase it.
thanks in advance
Micksta
WHERE TO BUY RETRACTOR RELAY FOR NA
90 ltd edition
Given you're in Melb & it's Saturday, call James at the MX5 Centre - he's usually there Saturdays from 10am to 5pm.
http://www.mx5centre.com.au/
8/200 Chesterville Rd Moorabbin - 0402 833 070 or 03 9818 6915
You can also email him via an online form at the above web site.
Does any one know if they make a non Genuine retractor relay
if so please share
micksta
if so please share
micksta
90 ltd edition
- green_comet
- Car Detailing Guru
Where is the retractor relay located?
micksta wrote:Does any one know if they make a non Genuine retractor relay if so please share micksta
I thought relays tend to be generic, i.e. Mazda may use a Nippon Denso relay which, in turn, may be used in many other vehicles. After some Googling, it looks like Mazda use an Imasen LA12 (see photo below).
There's probably an equivalent, so you could either try Repco or one of the other autoparts stores, or a Mazda wrecker. I recently bought a used LA10 (the one next to the LA12 in the photo) from James for a reasonable price.
Of course, there's also MX5 Mania in Sydney (one of our Forum sponsors), MX5 Factory in Ringwood, & MX5 Parts Plus in Brisbane. The Mazda wreckers that I know of are in SE Melb, (Dandenong, Clayton & Carrum Downs), but I'm sure there are others around Melb.
- Mr_Q
Is the relay you want the one in the engine bay or the one under the steering column? If you're having problems with the lights not popping up when you turn them on then it's probably the one under the steering column.
Mister Q
Mr_Q, I believe the relay is an LA12 whether it's in the engine compartment or under the steering column. Its location seems to vary from model to model &/ or country to country. For example, when I checked the location of mine it wasn't in the engine compartment as per photo from the Internet which was from a US vehicle.
- Mr_Q
93_Clubman wrote:...Its location seems to vary from model to model &/ or country to country
Fair enough. I replaced it on both my '91 and '93 Oz delivered NAs and it was under the steering column on both, so only speaking from personal experience. My current car doesn't seem to have a retractor relay for some strange reason ...
Mister Q
