window switch broken??
wun911
Postby wun911 » Tue Nov 25, 2008 11:01 pm
NB8B...
Passenger window swich works window goes up and down.
Drivers window swich does not; window is stuck fully up.
I dont think its a broken fuse...
Anyone else ever have this problem?
every ounce counts
Jace
Postby Jace » Wed Nov 26, 2008 8:04 pm
not specifically, but it's more than likely a snapped cable.
take off your door trims and have a look/feel around.
check to see if any part of the window mechanism is jammed.
grump
Postby grump » Wed Nov 26, 2008 8:20 pm
could be contacts inside the switch need a clean
crzymx
Postby crzymx » Wed Nov 26, 2008 9:07 pm
Dont jump to conclusions. What it could be. First and formost is the switch itself. You need to pull it out, then pop out the tabe revealing an inside screw. Unscrew the screw and take the pannel off. You need the reveal underneath the buttons as sometimes the little tabs snap. Meaning it makes no contact with the rocker switch on the citcuit to operate the window. In my case the tabs to go down were broken, tabs to go up werent. If this is not the case. With the module open, get some contact cleaners and clean the black grime off the contacts. If that fails your looking at maybe a faulty motor if the cable is not snapped. U can jumpstart it by banging on a little spot near the tweeter where the motor is. This is all for my nb8a so id ont know how much it differs with yours.
DIY is the new black!
RG.net
Postby RG.net » Fri Nov 28, 2008 11:39 am
how about you dont worry about it, strip all the electrics and make them manual windy ones, cmon prince of liteness :lol:
blue_na
Postby blue_na » Fri Nov 28, 2008 11:42 am
MXHEVN wrote:how about you dont worry about it, strip all the electrics and make them manual windy ones, cmon prince of liteness :lol:
I'm suprised he still has windows, heaps of weight to save there! 8)
The emotion of motion... Zoom-Zoom!
Postby Okibi » Fri Nov 28, 2008 2:52 pm
It's easy to use a jeweller's screw driver to swap the passanger/drivers wires around so the passanger switch will do the drivers side window.
Do that first so you can tell if it's the switch or other wiring/window mechanism.
I think I have some photos at home on how to pop the wires out to swap them over.
wun911
Postby wun911 » Sat Nov 29, 2008 12:43 am
I have taken it out to weigh/inspect.
The switch itself has lost contact and no longer 'clicks' like the passenger side.
Will take it apart with mini screwdrivers later.
Thanks for the helps
every ounce counts
crzymx
Postby crzymx » Sat Nov 29, 2008 4:16 am
Well that click sound is made by the little tabs that contact with a rocker type switch. there are two tabs for each switch and are absolutely tiny so they break after excessive use. If thats the case ur in for a new switch.
Alf
Postby Alf » Sun Nov 30, 2008 9:27 pm
~$140 for a $5 switch. :shock: Have a look at Mania or MX5 Factory for s/h stock
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
wun911
Postby wun911 » Wed Dec 03, 2008 9:48 am
got a new switch for $60 all is good now...
every ounce counts
