MX5CHIC wrote:I'm not sure what model you own there
I always forget to mention what model I have... for some reason I just assume everybody knows
It's an NB8A.
MX5CHIC wrote:I assume from your post that you have turned the A/C Switch on and the Cooling Fan is actually Blowing Air? if yes then we can go from there ...
1) Take a look over all visible air conditioning High and Low pressure tubing (aluminium) and also get a good torch and check your Condensor in front of the Radiator - look carefully for Oil especially on the connections and the Reciever Dryer (it looks like a Coke Can located in the engine bay) although it's not red - just alloy.
Oily residue is a good sign that you have lost your Gas charge, you only have to lose 5% of your charge to have a significant affect on your cooling.
Yes, fans are blowing air, yes air conditioning is turned on (valid questions... sometimes people do silly things).
Looked over all the tubing and receiver/dryer and couldn't see anything liquid or leaky along the tubing. I'm a bit lost as to where to find the condensor though. When you say in front of the radiator, do you mean it's forward of it essentially in the nose of the car, or do you mean on the engine side? I'm guessing it's the nose side because the only thing on the engine side was the fan and some motor thing attached to the fan, which I'll assume is the fan motor. Either way, what should I check on the condensor (when I find it)?
MX5CHIC wrote:2) On most Receiver / Dryer units (at least on NB's) you will see a plug which should have 2 wires - this plug is attached to a Pressure Switch within the unit. If you have a Multimeter or test lamps test for a circuit here first, the easy way is to pull the plug out then test continuity across this pressure switch. If you are not electrically blessed then you can go to this next step.
Took the plug out. Tested the voltage across the plug (obviously there's no point testing across the receiver/dryer because that's the device that needs the voltage... it won't be putting anything out) and confirmed it was working. Was getting something like 11v across it when the air conditioning was turned on and 0v when the air con was off, so that all looks alright.
MX5CHIC wrote:3) You should check if there is any Gas at all in your A/C System, on the Receiver / Dryer ther should be two Caps, Unscrew one of the 2 Caps preferably the one marked "HP" - it looks like a Tyre Valve, very quickly press down on the valve inside the removed cap and if there is any charge you will hear Gas escaping. If you hear nothing at all then DO NOT PROCEED with the next step as you have no gas charge at all (take it for repair as you have a major leak).
Pressed the valve release under the HP cap. I was getting gas escaping so it seems that there's still gas of some sort in there. It seemed like a fairly strong bit of pressure coming out of there, although that's only an observation on my part. I have no idea whether that means anything at all.
MX5CHIC wrote:5) Once you have bridged (shorted) these wires, start your engine leaving the bonnet raised and the A/C Fan running then lean in and hit your A/C Button - if you are low on Refrigerant Charge the Compressor will kick in and run; BUT turn it off quickly as it can cause damage to the compressor if the charge is too low - generally the vast majority of systems develop slow leaks from dried "Ö" Rings and a system can be locked out by the pressure switch with only 10% gas loss, you can avoid this by regulary running you A/C System over winter months.
This is what I have yet to try because I'm a little confused with the instructions. What should I be shorting? Should I be shorting the terminals on the receiver/dryer? Knowing that I've confirmed that the wiring from the A/C button to the loom generates a voltage across the plug, essentially plugging the plug back in and pushing the A/C button should have the same effect as shorting across the terminals of the receiver/dryer yes?
Now, assuming that I did short the wires/terminals/whatever and the compressor kicked in, what should I be looking for? Should I be checking for cold air coming through, or should I just be confirming that the compressor runs at all?
MX5CHIC wrote:That is a quick and basic way of checking - if you are good with wiring circuits and the use of a Multimeter then I'd suggest testing the circuits to ascertain a pressure switch lockout.
If this test is succesful you need to look for leaks, a big problem with MX5's is stones hitting the Condensor - I've already replaced one for this reason ..... now I have a Grille.
So is the pressure switch essentially that voltage drop that's being applied to the receiver/dryer?
Thanks very much for the advice everyone's given so far. If I can get a bit more info I'll give it another looking over tomorrow, but so far it seems like I'll be paying a visit to the mechanic to see who he recommends for electrical/air con work...
