NB8B door speakers
robbie9394
NB8B door speakers
Postby robbie9394 » Wed Oct 15, 2008 6:25 pm
Hey guys
Have a simple ... but irritating Question
i'm sure this has been asked b4, but just wanted to make sure with people who have had first hand experience with this !!
I am considering to buy splits for the doors
so .. the question is ...
what size speaker will fit into the door with MINIMAL MODIFICATION to the door trims (NB8B)??
I am looking at a pair of pioneer splits (TS-D1720C) which are 17cm
Will these fit ?
Cheers :lol:
philz
Wheel guru
NB8B door speakers
Postby philz » Wed Oct 15, 2008 6:36 pm
Anything from 17cm and under is fine.
You could probably fit 8inch with a spacer.
NB8B door speakers
Postby sliq » Wed Oct 15, 2008 7:00 pm
6x9's and 6's fit.. the oem size is 6 x 8.
robbie9394
NB8B door speakers
Postby robbie9394 » Wed Oct 15, 2008 7:29 pm
sliq wrote:6x9's and 6's fit.. the oem size is 6 x 8.
Most 6x9's are too deep...?
Heard that it could interfere with the electric window/motor ...
robbie9394
NB8B door speakers
Postby robbie9394 » Wed Oct 15, 2008 9:36 pm
Sorry bout the noobness ...
OEM is 6 x 8 .... if i install 6 x 9's .. does it require cutting doors ??
i would prefer to install 6 x 9's if it doesn't need cutting
i have found eclipse 6 x 8 speakers ...
http://www.eclipse-web.com/integrated/se6800.html
The specs aren't ... mind-blowing to say the least
Garry
NB8B door speakers
Postby Garry » Thu Oct 16, 2008 8:14 am
There's heaps of depth to play around with. BTW 8" round speakers will fit without a spacer, you can even use the factory speaker holder mounting points to attach them. The speaker cavity is designed to fit 8" speakers for the markets that come with the BOSE setup.
Why dont you take the door card off and have a look for yourself? 3 screws, a few clips and an electrical plug and it's off, then you can take all your own measurements and work out what will fit and what wont..
wun911
NB8B door speakers
Postby wun911 » Thu Oct 16, 2008 3:42 pm
Im using 20 cm round speakers in an NB8B door, and yeah its quite deep.
every ounce counts
robbie9394
NB8B door speakers
Postby robbie9394 » Thu Oct 16, 2008 4:53 pm
thats good news =)
so basically .... from what i have gathered from this thread ..
the following speakers should fit with no problem ...
6 x 9"
6.5"
8"
ASE05
NB8B door speakers
Postby ASE05 » Thu Oct 16, 2008 8:25 pm
wow, I could whack a set of 6x9's in the doors of the SE hey...... 8) ?
Sing that song, puff all night long.......
NB8B door speakers
Postby Okibi » Fri Oct 17, 2008 12:13 am
Don't bother with 6x9's they're for the backshelf of the commode-ore, get some 8" rounds, easy fit. :mrgreen:
robbie9394
NB8B door speakers
Postby robbie9394 » Fri Oct 17, 2008 2:04 pm
i wouldn't mind 8's ....
though ... i don't know of a reputable speaker manufacturer that makes speakers in 8" :|
always thought that 6 x 9's sound better then 8's anyhow... true or false ???
philz
Wheel guru
NB8B door speakers
Postby philz » Fri Oct 17, 2008 2:38 pm
How much are you willing to spend?
And will they be powered by an external amplifier?
edit: 6x9 don't sound as good as 8.
They have more surface area, but the cone , not being round/ circular and induces distortion of the cone.
Though you need to be a audiophile, and spend big to notice.
$100 6x9's vs $100 8's will sound no different.
bigdog
King of the kennel
NB8B door speakers
Postby bigdog » Fri Oct 17, 2008 5:20 pm
philz wrote:$100 6x9's vs $100 8's will sound no different.
Geez Phil - $100 for 8" speakers? Ripped off! Mine were only $20! :P VDO (Phillips) 8" 100WRMS FTW!!
hint - check your local Repco - they might still have some left :D
wun911
NB8B door speakers
Postby wun911 » Sat Oct 18, 2008 3:30 pm
Pioneir made them 8" round... not too exey
every ounce counts
robbie9394
NB8B door speakers
Postby robbie9394 » Sat Oct 18, 2008 6:46 pm
wun911 wrote:Pioneir made them 8" round... not too exey
Sorry .. but what does exey mean ??
Typo ??
