wind screen wipers and washers stopped working on na6
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 5:03 pm
hi all, on the way home today the windscreen wipers just stopped working when went to turn them on and same with the washers, I am guessing it may be a fuse. If anyone knows of a easy fix your help would be greatly appreiciated.
Cheyne
90' NA6 - Classic Red
Fatty
Postby Fatty » Sun Sep 07, 2008 5:16 pm
CheyneX5 wrote: I am guessing it may be a fuse.
well have you actually checked the fuse yet?? :lol: :? :? :lol:
seems like a good place to start eh!??
(fusebox is in the drivers footwell on the side near the door)
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 5:30 pm
I shall check shortly *runs*
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 7:08 pm
well i looked at the fuse box but have no idea of which fuse to check... :? anyone know?
Fatty
Postby Fatty » Sun Sep 07, 2008 7:25 pm
if you have a look at the lid of the fuse box, there is a diagram showing what all the fuses are for.
your wipers fuse is the 20A fuse in the top right hand corner.
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 7:36 pm
ah cool, i will stop via jaycar tomorrow
Fatty
Postby Fatty » Sun Sep 07, 2008 7:46 pm
pull the fuse first and check if it's stuffed or not.
bensale
Postby bensale » Sun Sep 07, 2008 8:19 pm
Good work fatty :D Check it is actually the fuse before you buy anything.
As a matter of interest how would you tell that the fuse is stuffed? Is it like a light globe? Otherwise would you just put anouther fuse (the heater one or something) in place of the wiper one and see if they work?
www.othersideproductions.com
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 8:33 pm
im guessing thats what you need to do, i mean 50c, cant go wrong. might go and treat my self to some bosch aero twin wipers tomorrow too. but one thing, where do i unclip the oem wipers?
Fatty
Postby Fatty » Sun Sep 07, 2008 8:37 pm
ben, generally you can just tell by looking at the fuse - see how the bit in the middle is toasted?
blown fuse:
good fuse:
sometimes it can be hard to tell by just looking at it, in which case test it for continuity with a multimeter.
Juffa
Postby Juffa » Sun Sep 07, 2008 8:45 pm
What Fatty said.
J
Postby Mr Morlock » Sun Sep 07, 2008 9:23 pm
Always useful to have a glovebox owners manual which often covers all these basic questions. If the fuse is blown bear in mind that something caused it and if it blows again quickly then there is a glitch somewhere.Make sure you have a few spares for contingencies. With windscreen wipers I merely replace the rubbers at least annually or whenever they are not doing the job- the cost is then quite nominal in order of $10-15. The Bosch unit includes the arm assy though you will still have to replace the rubber when they deteriorate.
bensale
Postby bensale » Sun Sep 07, 2008 9:26 pm
Ah ok cool, too easy! Thanks
CheyneX5
Postby CheyneX5 » Sun Sep 07, 2008 10:23 pm
That's all well and good but I still don't know how to remove the oem wipers
TieNN89
Postby TieNN89 » Sun Sep 07, 2008 11:10 pm
bit off topic
but does MX-5s carry spare fuses? at all?
