ECU stuck in open loop while idling??? NA6
Posted: Tue Aug 19, 2008 5:57 pm
i had a bit of a mishap when disconnecting the battery yesterday, i was undoing the - terminal and my spanner touched the + terminal and put on an impromtu fireworks display for me.
so i don't know if it's related, but now the car is not going into closed loop when it's idling. it's also running very rich at idle. i have only discovered these 2 symptoms as i have an AFR metre in my car. it's going into closed loop when cruising, so the o2 sensor is working , at least while cruising.
so i am a bit worried i may have fried some of the electronic doodads, ecu, sensors (most likely the o2 sensor as i know it is rather sensitive) etc when i short circuited the battery.
also, after 30 seconds or so of idling normally (apart from the fact that it's pig rich and in open loop) , it sometimes suddenly starts doing the idle down / idle up that we all know and love. it's doing it rather badly too.
anyone got any thoughts on this? seeing as it's just developed really suddenly and chronically i'm not sure it's the normal idle problem that others often talk about.
