Has anyone with an NB8A added an additional 12v Socket?
I'm sick of changing gears and hitting my phone charger
Additional 12v Socket (NB8A)
- TieNN89
- redwards
I'm not particularly familiar with the NB dash... Zombie has one of those quadruple adaptors in the cubby hole.
Given you use your phone charger pretty often, have you considered hard-wiring it in?
Former owner of a white 1994 NA8 Clubman
- TieNN89
- marcusus
Why do you charge your phone so often? As an easier fix than rewiring stuff, why not just charge it at home? The charger that gets given to you in the box is much more efficient at charging your phone than the el cheapo car chargers.
My advice would be to just keep the 12v car charger in the glove box in an emergency, and just do all your mobile charging through your regular mains power. That way you can also keep the look of your car interior much nicer without having the hunk of plastic sticking out of the console. Oh, and your shifts will be a lot easier too
- TieNN89
marcusus wrote:Why do you charge your phone so often? As an easier fix than rewiring stuff, why not just charge it at home? The charger that gets given to you in the box is much more efficient at charging your phone than the el cheapo car chargers.
Well lets say my phone is also a GPS unit which drains battery faster than ever so I need 12v to run it
Yes I always charge my phone at home but I pretty much drain the battery within 1 an half days LOL
- redwards
AZNTieN wrote:Yes I always charge my phone at home but I pretty much drain the battery within 1 an half days LOL
Same here, but that's cos the battery's shagged.
A little off topic here... DID YOU KNOW...? Lithium Ion (unlike NmH) batteries are not designed to be (1) left on charging the whole time and (2) should not be drained. They last best with lots of ~50% charges. Leaving them on to charge too much apparently raises the temperature and can cook them.
Thank you Wikipedia.
Explains why my laptop battery had a life of 3.5hrs, now has around 35mins - I left the battery in and the powerpack on 24/7 for a year or two
And now you know! AND KNOWING IS HALF THE BATTLE!
- bruce
- Vehicle: NA8 - Turbo
Hey, don't tell people that. I make a good living outta selling new mobile batteries to all the dills who bugger their batteries!
- davekmoore
To go back to the original topic, erm, a year later, I'm having the same problem with the gearlever knob or my fingers hitting the phone charger where it plugs into the 12v socket. Get a short shifter I hear some say. Or stiffer engine/gearbox mounts so the shifter isn't being moved about so much when it's running 14psi. Not bad ideas, but maybe there are cheaper options?
Not being an electrician, but either being prepared to have a go myself, or wanting to avoid looking too much of a fool if I seek professional help, where can I either re-site the existing 12v socket (and how to fill the original hole?) or fit an extra 12v socket, or should I just get something hard wired?
Whatever gets done need to suit a USB outlet to charge an iPhone and might need to have more than the normal output because said iPhone is usually used as satnav, mp3 player and phone, amongst other things, usually 2 or 3 of them at the same time and loses charge, along with gaining heat, very quickly. I may also want to use other items including a cool box, and a 240v inverter which plugs into a normal 12v outlet and would power things like my laptop.
Ideally I'd also like this setup to be a) permanently live and b) to have some way of both this setup and all the other electrics powering down if the battery loses so much charge that it would no longer start the car. a) is so the coolbox could keep running when I'm out of the car. b) is to avoid the flat battery I had last week when I left the sidelights on all day (doh! - I know there's a warning buzzer. It was disabled with masking tape over the sensor because I'd been working on the car the night before. Yes, I always carry a booster pack. I took it out the night before.)
Back when I spent many late nights driving and using a UHF hand held radio (with ciggy charge attachment) I had a double socket point that I got from a generic car parts supplier that I located between the seats, did the job well. Sorry I don't have any photos.
- MX5CHIC
I did and I also have a Mobile with GPS (Nokia & Garmin Maps) - I had a dual outlet installed in my old NB8A console, wiring was easy, up through the console from the dash. I am now considering fitting an extra outlet in the small space to the right of the steering wheel just above the fuse box.
Another solution which I currently use is a car kit for ipods and iphones - "ALLTRAX" Brand $49.95, it has a bendy stalk with a holder, built in plug for charging iphones & ipods, radio transmitter which works great and a free USB port for charging anything USB.
I have an AUX input jack for my stereo, so I just plug it directly into the ipod touch.
- de Bounce
I found if you zip tie the lead to the body of the charger , it won't interfere with the gear changes.
you can easily buy a power cord with dual outlet plug- simple cheap and effective.
I put a second cig lighter socket in the glove box. The cable was thin enough to run out through the glove box opening when it was shut and cig lighter in use, and then would just go back into the glove box when not in use. I just wired it from the back of the factory cig lighter, de-commissioned the factory lighter. The socket in the glove box was on the end of a longish cable so that I could run it out into the cabin. Worked well for me
Edit: just re-read this and it could be misleading
The cig lighter was wired from the back of the factory one, and the lead then went around behind the console and into the glove box, where it connected to a new cig lighter socket.
