LED blinker replacement
Postby Mr Morlock » Wed Aug 06, 2008 8:47 pm
Hella should be able to tell you- the problem of flash rate is well known with LED's though I have not personally fitted them. One of the Hella companies produces LED lamps so they are not just sourcing these from some 3rd party.If you did not buy Hella lights then maybe the co you bought them from should be giving you the info. In theory the light output is much the same but leds have a different appearance.Some cars are starting to use leds but it does add cost for no big advantage.
Your flat battery problem is still to be fixed- it will not be related to your lighting- most of us have standard lamps and have no problems.
mx52nv
Purple Porsche Eater
Postby mx52nv » Wed Aug 06, 2008 9:34 pm
Mr Morlock wrote:Your flat battery problem is still to be fixed- it will not be related to your lighting- most of us have standard lamps and have no problems.
100% agreed here - please don't go replacing parts until you have found the current draw. Any auto electrician should be able to help.
bensale
Postby bensale » Wed Aug 06, 2008 9:51 pm
The fact that you leave your parking lights on could explain your flat batteries. I did it once as they are quite difficult to spot, perhaps the fact that the flat batteries occur on rainy days could be due to the fact that you are more likey to use your parker in that weather. I conected a little buzzer to two fuses so that it never happens again.
www.othersideproductions.com
redwards
Postby redwards » Wed Aug 06, 2008 10:03 pm
By the sound of the original post the reason for the current draw is someone forgetting to turn the lights off.... LEDs would draw less current than incandescents and therefore not drain the battery overnight...
The hardest part is the indicators.
If you're still keen, it appears you need new or modified relays. Check out these links: http://www.gassavers.org/showthread.php?t=1558.
And this one: http://www.instructables.com/id/Automotive-electronic-flasher-rate-modification./.
In short: not for the faint hearted.
With the second approach, there's a distinct possibility that you could fry your electrics. Good for slowly changing the three sets of indicators on each side of the car.
[edit] ooh, and bensale jumps in with the 'let your lights on, eh?' call while I'm still typing,
Former owner of a white 1994 NA8 Clubman
Garry
Postby Garry » Thu Aug 07, 2008 9:31 am
Not that it's going to be much help to you but a lot of the motorbike guys replace their indicators with LED's. All you need to do is add a resistor to the circuit somewhere so that the flasher unit recognises a load when the LED's are illuminated. I'm not sure where you add the resistor (though I'm pretty sure it's external to the flasher unit) or what value you use though. Sorry.
Postby bruce » Thu Aug 07, 2008 11:03 am
Simple solution: do not use your parkers. Just use no lights or full headlights. Parkers are the most useless invention and I have no idea to what purpose they serve.
Postby Mr Morlock » Thu Aug 07, 2008 3:17 pm
bruce surely you cannot be serious that you do not know and recognise the value of parkers? PS switching leaving lights on and running your battery flat is something most people do once and many cars send an audible warning when you remove the ignition key if parkers or headlamp remains lit.
Postby Okibi » Thu Aug 07, 2008 3:40 pm
bruce wrote:Simple solution: do not use your parkers. Just use no lights or full headlights. Parkers are the most useless invention and I have no idea to what purpose they serve.
I agree with this for every day driving, I can't remember when I last wanted to put just the parker lights on.
Postby bruce » Thu Aug 07, 2008 4:32 pm
The value of parkers is zero. People cannot see them when they are switched on, so what is the point of having them on. Full lights or no lights. (I believe Parkers are called such because you switch them on when parking your car, not for driving around with).
(Seriously, how can you get 5 flat batteries in a row? You can push start an MX5 by yourself ya know. Instead of replacing your lights why don't you just install a buzzer to tell you when the lights are switch on?)
Postby Mr Morlock » Thu Aug 07, 2008 6:30 pm
The value of "parkers"? The remark that they are of zero value and people cannot see them holds no water. Parkers are there for the very purpose of providing an opportunity to be seen. They are 5w's the same as turn signals and we can all see these. The parker can be switched on in poor day light conditions such as tree lined roads which simultaneously also puts your tail lights ( 5w) on- think of light fog or where you have no fog lights. It also avoids having to put on headlamps during the day under poor light or light rain when headlights do distract other drivers.
Stopped on the side of the road or parked in a narrow street the parker might save your car or someone running in to you. Leaving your headlights on or your hazards is not a sensible option for these conditions. I might add that 5w parkers in a modern large headlamp provides a surprising amount of visible light.
I often drive with parkers on, or fog lamps as a low, sports car is not easy to see on tree lined country roads though fog lamps may draw attention from the constabulary.
Fatty
Postby Fatty » Thu Aug 07, 2008 6:55 pm
redwards
Postby redwards » Thu Aug 07, 2008 8:39 pm
I've considered LED light replacement - one of many things I'm considering with my 5. bpt4w: how much did all the lights cost you?
[Thread hijack! :twisted: ] In defence of parkers: I disagree with the argument that parkers are useless - but that's because I have an NA. In any other car I drive in, it's full headlights or nothing. But the NA eyes pop up - that interferes with air flow, blocks your view a bit (albeit not much) and I like the look of the car with parkers on. Headlights are only on when I need to see where I'm going.
bensale
Postby bensale » Thu Aug 07, 2008 11:51 pm
or just buy a cheap buzzer and wire it it. I'll find the fuse diagram for you.
Ben,
tbro
Postby tbro » Sat Aug 09, 2008 7:30 pm
[quote="bpt4w"][color=#0080FF] how to modify the blinker unit to remove the blown bulb function (thus making the leds flash at a proper rate) .
bpt4w, whip down to Ashdowns,repco or any decent auto elec supply co and ask for inline LED resistor and wire up in line
Part no for OEX is ACX2023
I use these all the time on my trucks when I fit LED units to the rears. Hella, Narva also produce them.
note: if you fit them and it doesn't work unplug and swap connectors as they have a right way to fit them.
the reason the failed lamp comes on and they flash quickly is that LEDs use approx 5% of power compared to std bulbs.
The biggest drawback apart from cost is the lamps are not clearly visible from side angles.
You can measure the resistance from your old bulbs and buy resistors to the same value, but I think you'll find the above a damn sight easier.
Terry
