My Lowbeams don't seem to turn on anymore
It was working this morning
High beam works but the high beam indicator on the instrument don't lit up
Fuses checked all good
Anyone?
Headlights don't work
- TieNN89
- JBT
I can only think it has something to do with the light stalk/switch.......or maybe a relay
Suggest changing the fuse even if it looks ok. You can check to see if you are getting power up to the fuse box ie the power in side. Check the power out side of the fuse box to so see if you have power. If you have access to the wiring diagram this will help to pin point relays ( you can check relay for power in and out as well.. I do not know enough to comment about the combo switch- would it give you high beam but not low?
- TieNN89
yes high beam not low
ITs ok now
Blubs died LOL
even tho i looked at them and they look fine
I guess you can't tell if a bulb has died or not if you look at it
Strange how both died at the same time
ITs ok now
Blubs died LOL
Two bulbs gone at the same time- very odd. Were they blown or the filaments just broken. Makes you wonder if there was some sort of power surge ?? If they were H4 bulbs they of course have 2 filaments for low and high. Anyway looks like you can see again.
- TieNN89
well both blew at the same time so i thought it can't be the bulb
so i checked fuses check switch .....
went back to the bulb and checked and it looked perfect nothing broken inside looks like new but just outputs nothing unless its on high beam
well yeah its all good now i got myself 2 new bulbs
- Steampunk
If I were you, I would look into this more indepth Tien, cause having 2 bulbs blow at the same time, although not impossible, is highly unlikely
- bruce
- Vehicle: NA8 - Turbo
Both my low beams popped at the same time too. High beams OK, everything else was fine. That was in a 90 NA. I thought the worst too...
