High Spec alarm chirps
- TieNN89
Re: High Spec alarm chirps
circus wrote:I ordered a new 2008 NC Roadster with the high spec alarm. I picked the car up early and arranged to have the alarm installed at the 1000km service. In the meantime, I read the alarm manual, and decided that I didn't want the loud chirps on arm/disarm. I requested this at the service - Eurocars Mazda in Sydney - but was told on picking up the car that the alarm didn't have this option. I said yes it did, it's written in the manual. The best the guys at Eurocars could say was "maybe it's referring to the European model".
So I thought I'd program it myself. Oops.
The manual that I have - European/Australian/who knows? - says that a combination of arm/disarm/turn the key a set number of times will turn various options on and off, including chirps. But it hasn't worked for me. Now, whenever I open the boot, the indicators flash five times. And it still chirps on arm/disarm.
Anyone had the same problem or know where I can get the right manual? Any other ideas?
i have this problem, it happened last year and i still havent been able to fix it
- Benny
- PB
Nothing wrong with it. When you unlock the boot via the remote, it actually de-activates the alarm. This causes the indicator lights to flash 5 times - highlighting that the boot alarm has been de-activated (doors remain alarmed) If you unlock the boot by pressing the button in the car, with the keys in the ignition... the lights will also flash 5 times. An additional warning system i guess.
Not sure how to dis-arm the sound though. They're not that loud?! One small beep for lock... two for unlock.
- AJ
our Sprinter van has a high spec Mongoose alarm that chirps on the lock & unlock function, but to get around it (told this by mongoose themselves) we just hit both buttons at once when locking, & it doesn't chirp to lock, then when you use the single button to UNlock it, it doesn't chirp either....................obviously a manufacturers work around for those (like me) who detest the chirping.............worth a try
cheers,
AJ
cheers,
AJ
XMX5 Rogues
