Centre brake light not working
- bigdog
- King of the kennel
And no, it's not the bulb - changed it twice just in case
Any thoughts on why this might be? I assume it is not separately fused and works in circuit with the main brake lights? The loom looks to be intact so I'm kinda scratching my head on this one. When I get a minute I'll go over everything with a voltmeter and try and sort it out, but I thought someone may have come across this before??
- SuperMazdaKart
it's common on NAs since the wiring tied to the bootlid hinge breaks after lots of bending from the bonnet going up & down
Last edited by SuperMazdaKart on Thu Jul 17, 2008 1:59 pm, edited 1 time in total.
- Brad
- Brad
- bruce
- Vehicle: NA8 - Turbo
- bigdog
If you have someone activate the brake you can check with multimeter or test probe to see if the wire is hot.. and trace back. I would have thought the centre high mounted stop light would be on a different circuit to your rear combo lights as a safety feature. If the fuse goes you would expect one circuit to still function rather than lose all 3 stop light function.
- bigdog
bruce wrote:Plus, your rear was repaired, so it may be related to that ?
I wouldnt go talking about bigdogs rear if I was you Bruce
Mazda Tribute - its a boat
- bigdog
- sliq
- bigdog
- bigdog
