Unless you use a key to turn off the siren prior to disconnecting the battery, most alarms go off when the battery is reconnected.
That battery light sounds alarming. Do you have a multimeter to measure the voltage across the battery terminals while you get someone else to rev the motor? If there is no change in voltage, the charging system is faulty, and you wouldn't be able to drive far, like >50km during the day before the battery is completely drained.
Battery light stays on
- Wuey
- marcusus
