drivers side door actuator
silvermiata
Postby silvermiata » Mon Jun 02, 2008 10:16 am
i have put an alarm system in my car recently, and i have put a jaycar actuator on the drivers side door, however, because of the extra thickness of the actuator, i can hardly put the door skin back on... and i can hear actuator is rubbing against the door skin...
has anyone experienced this? is there any trick? i am thinking about taking it apart again and shaving the actuator from both side so it would be skinnier?
Garry
Postby Garry » Mon Jun 02, 2008 10:25 am
You need to relocate the actuator to another spot. The ones I have fitted to NA's didn't rub on anything and the door trim fitted back on with no issues.
silvermiata
Postby silvermiata » Mon Jun 02, 2008 10:29 am
i have seen the inside of the NA door online, it is different to nb's (i have an NBthe way i did is how it shows on miata.net..but maybe their actuator is skinnier.. i will take it apart and have a look, but has anyone experienced this before?
