Spastic headlights
Posted: Thu May 22, 2008 5:47 pm
by lil_mike
ok, sort of interesting issues i'm having with my NA6.
firstly, the headlights come on whenever the car is on. not saying they pop up, just the lights are on constantly. what the hell would be causing this?
secondly, and this one is entertaining. When you push the button that makes the headlights come up without turning the lights on, they go spastic. they go up and down at different speeds and they just keep doing it. its like watching someone with an incredibly obvious twitch on fast forward.
any ideas?
Mike
Posted: Thu May 22, 2008 8:59 pm
by Juffa
With regards to the head lights always being on, I have had a similar issue. It was due a fault in the wiper/headlight/turn signal electrical switches mounted around the steer column. Try pushing the headlight stalk forward and see what that does.
As for the lights going up and down. Are the lights on when this happens. Try it again after pushing the headlight stalk forward and let us know what happens.
J
Posted: Fri May 23, 2008 5:51 pm
by Mr Morlock
lil mike I am being lazy but I am pretty sure there are some posts about why your pop ups cycle when they should not. It might have been on the Miata garage. Careful about getting your hands in the way if you are fault diagnosing other wise you might have to change your moniker to 4fingersmike.
Posted: Mon May 26, 2008 9:26 am
by lil_mike
Mr Morlock wrote:lil mike I am being lazy but I am pretty sure there are some posts about why your pop ups cycle when they should not. It might have been on the Miata garage. Careful about getting your hands in the way if you are fault diagnosing other wise you might have to change your moniker to 4fingersmike.
ah thanks, i'll have a look there. four fingers hey, well, i could think of worse parts to lose in a headlight motor :lol: i'll be careful though
Posted: Tue May 27, 2008 5:17 pm
by lil_mike
nope, no luck. couldnt find any articles related to the issue.
back to square one i guess.
Posted: Tue Jun 03, 2008 11:55 am
by nfs13b
when I was stuffing around with the wiring on my car the waving lights was caused by a bad earth and there is also a relay I think in the engine bay.
Posted: Thu Jun 05, 2008 9:08 am
by lil_mike
nfs13b wrote:when I was stuffing around with the wiring on my car the waving lights was caused by a bad earth and there is also a relay I think in the engine bay.
Hmmm, i'll have a look at that this afternoon then. do you know where abouts in the engine bay the relay is?
Posted: Thu Jun 05, 2008 9:20 am
by nfs13b
nah i dont. I pulled all the wiring out of the engine bay and reran it all down the drivers side so I dont know where it originally was.
Posted: Sat Jun 07, 2008 11:48 am
by lil_mike
i think i found the relay, just gotta replace it now.
Posted: Fri Jun 20, 2008 4:39 pm
by lil_mike
scrap that, it wasnt that relay. whats happaning is something else. When you turn the 'pop-up' button on the motors just keeps turning, it doesnt stop. this then causes the headlights to continue going up and down.
anyone have any ideas on how to stop it doing this?
Posted: Fri Jun 20, 2008 5:25 pm
by Mr Morlock
I think you need to get the wiring diagram and talk to a mechanic or auto elec.If you cannot read the wiring dia they will. You can also get out library books and a Haynes or such like gives run down on finding faults- borrow a multi meter and keep yr fingers well away from cycling lights. If it cycles then it is not getting the signal to cut the current.
Posted: Fri Jun 20, 2008 7:26 pm
by Mr_Q
There's another relay for the headlights under the dash. Haven't heard of it causing the problems you're having but might be worth a look.
It's right under the steering wheel, just above the pedals. It's next to the indicator relay.
I found it/replaced it when my headlights sometimes wouldn't pop up (they'd light up, but not raise up).
Posted: Sat Jun 21, 2008 10:43 pm
by lil_mike
Mr Morlock wrote:I think you need to get the wiring diagram and talk to a mechanic or auto elec.If you cannot read the wiring dia they will. You can also get out library books and a Haynes or such like gives run down on finding faults- borrow a multi meter and keep yr fingers well away from cycling lights. If it cycles then it is not getting the signal to cut the current.
yeah i learnt my lesson about keeping your fingers out of the way. almost lost them.
i'll have a look at the wiring diagram then, hopefully can convince electrician friend to help.
I'll check that relay too, thanks Mr_q
