NA8 antenna
lil red rocket
NA8 antenna
Postby lil red rocket » Wed May 07, 2008 9:33 pm
:( Team
I have a 95 NA8 with a crook radio antenna - doesn't go up or down. I tried to remove it for replacement or repair. After removing all visible screws, nuts and electrical connections it was still held to the bodywork. I'm generally fairly cluey but this has me stumped. Anybody removed one? Any advice? Please Heelllpppppp! :cry: :cry:
[color=#BF00FF]I like it! I like it a LOT!
http://www.cardomain.com/ride/3368773/3
Tezzax5
Postby Tezzax5 » Wed May 07, 2008 9:49 pm
Does it still make noises when power is applied or turned off..?
If it does then you will need to get a re ribbon kit from mazda.
Or get a whole new kit....NOO7 66 930A assuming that 95 and 94 are the same.
Have you undone where the shaft goes through the bodywork?
Looking down from above Chrome disc with 2 small slots in it
Undo it with a pair of pointy pliers....points go in the slot
Unplug wires,undo the 2 mounting screws ,unplug plastic tube on the base of the unit where it goes to the body work and the whole lot should come out
If it doesn't make sense send me a pm with a phone number and i'll talk you through it
Tezza
lil red rocket
NA8 radio Aerial
Postby lil red rocket » Wed May 07, 2008 11:50 pm
:D MUCH Thanks Tezza. I'll try the needle nose pliers in the small holes. I'll keep you posted. :D :D :D :D
Steampunk
Postby Steampunk » Thu May 08, 2008 8:51 am
Brian, when you remove it, just leave it off as it's only extra weight which will slow your car down at the track :P
But more to the point, as Tez said, if it still makes noises, ie the motor still runs, then it may be just a broken snakey-thingy [technical term].
I found that on mine.
Follow Tez's instructions and you'll be right.
Andrew
