Posted: Tue May 06, 2008 11:21 am
It only takes a couple of minutes to get the door skin off.
I'd recommend doing it so you have an idea of what you need to do before you choose your speakers.
A well made MDF mounting plate can level off any contours in the door and cover with loads of silicon. If you're wanting some base replace the plastic rain coat with some dynamat style sheeting or the base will rattle everything in the doors.
