Help needed tonight, Alarm backup battery?
Alex
Postby Alex » Thu Apr 10, 2008 7:37 pm
I've been having problems with my alarm over the last week or so
basically I lock the car then the alarm goes off straight away and I have to deactivate it by unlocking via the remote, normally after about 5 goes it finally stops and locks as normal
I've been reading through the normal manual, security system manual and the workshop manual and nothing could be found out
so today I had a quick play around and it seems that the backup battery has decided to give up on me :frown: when in the test position it just wails slowly to death :(
so just wondering if anyone knows where the backup battery for the upgraded mazda alarm is kept (might want to PM me since it's a security thing) and/or what type of battery it is and approximate cost of replacement?
I'll see how the reply's go but tomorrow I'll be heading to the mazda dealer to see if they can help out as I would like this fixed up ASAP
TieNN89
Postby TieNN89 » Thu Apr 10, 2008 8:51 pm
not sure if the case is the same with the factory alarms but the battery is normally built into the siren
so you would need to replace the siren
Postby bruce » Thu Apr 10, 2008 10:21 pm
Is there a keyhole to disarm the alarm completely. Should be in the back of the siren. Thus the battery is in there. May be able to get one from Jaycar (the whole siren with battery) ?
Alex
Postby Alex » Thu Apr 10, 2008 10:37 pm
yes there is a keyhole, but when disarmed it still has the flashing hazards it only turns off the sound
I'm not sure if the battery is located inside that box either because I though backup battery was an extra option for the alarm system
Postby bruce » Fri Apr 11, 2008 1:44 pm
Battery is definitely inside the siren. You can either buy a straight siren or one with a battery backup. I'm 'guessing' the siren is just a dumb device so you should be able to buy one off the shelf.
Postby Okibi » Fri Apr 11, 2008 2:18 pm
I'm interested to see if you're able to resolve this, could be a bit of handy info.
Postby bruce » Fri Apr 11, 2008 5:12 pm
Remove one of the battery cables. All the lights should die and only the siren will sound.
Col
Vehicle: 10AE
Postby Col » Fri Apr 11, 2008 5:54 pm
Just dismantled my siren, hoping to find a battery which I could replace. What I found 'though was circuit board with a 6V 170mAh battery fitted. The battery isn't able to be replaced as it is soldered on to the PCB and held in place with some kind of adhesive. I gave up when I found this and just put it back together while I consider what to do next :roll:
Happy 10AE man [#5128]
TieNN89
Postby TieNN89 » Sat Apr 12, 2008 12:17 am
come on a new siren is only like 30 bucks from jaycar
http://www.jaycar.com.au/productView.as ... &SUBCATID=
may not look flash but as long as it does the same job
you could even add 2 in lol
Alex
Postby Alex » Sat Apr 12, 2008 1:31 am
ok well here is how it went
went to Mania to see if they could help out
no luck, alarm wasn't fitted on the imports so i couldn't just swap over the box
Mazda was called to see what they could do since it's listed as a \"genuine\" mazda alarm. They had no idea, headoffice supplied contacts for the company they had contracted to make the alarm system, the number turned out to be wrong. The proper company was tracked down and called, after the part numbers were given they said they did have one in stock but they didn't know if it worked or not so they would find out and call back, haven't heard anything yet so we will have to wait until monday
it's a bank of 5 batteries located inside the siren as others said, from the original maker we found out it's actually a bank of 5 batteries, to get it off a good hairdrier and soldering iron would be required, hairdrier for the glue and soldering iron to melt the solder
Jaycar don't stock the battery
It's a bank of 5 x 170BVK batteries, of the Sylva Charge brand
updated before tuesday hopefully
TieNN89
Postby TieNN89 » Sat Apr 12, 2008 7:20 am
no they don't
but can't you just replace the entire siren
TieNN89
Postby TieNN89 » Sat Apr 12, 2008 7:21 am
no they don't
Alex
Postby Alex » Sat Apr 12, 2008 9:17 pm
I was thinking about it but i'm not sure what else the siren is connected to, like the motion sensor in the cabin and the shock sensor
but if I can't find a battery I guess I'll just have to replace the whole thing but I'm going to use that as a last resort
Postby Okibi » Sat Apr 12, 2008 9:52 pm
AFAIK the microwave sensor is connected to the alarms control unit hidden up inside the dash.
Sounds like you can just replace the siren.
TieNN89
Postby TieNN89 » Sat Apr 12, 2008 10:13 pm
the siren should be completely seperate to the alarm
microwave and all that add ons are hooked into the alarm box which is usually somewhere else
