NA window speed fixed!
Postby manga_blue » Wed Mar 26, 2008 6:34 pm
30 minutes of tinkering just fixed 2 years of frustration. Windows now go up and down at normal speed, every time. :shock: :shock: :shock:
1. Disconnect battery.
2. Remove centre console.
3. Unscrew and remove window switch and unplug it from the loom.
4. Undo tiny brass screw that holds the switch (white bit) to the holder and rockers (black bits).
5. Holding in something containing like a pillowcase, gently bend back each tab of the holder with your fingers and free each lug of the switch.
6. When all tabs are off separate the switch and holder. More than likely the 4 little metal rocker arms will fly everywhere when you do this (hence the pillowcase).
7. Check the photo. All the positive contacts are blackened and covered in oxide and muck.
8. Clean each contact with metho then polish lightly with about 800 wet n dry.
9. Do the same for the metal rocker arms.
10. Re-position all 4 rocker arms in the switch. Don't force them, they only go in one way and they fall into place easily when you've got it right.
11. Clip the holder back on over the top of the switch. Replace and tighten the brass screw. Good idea to test with a multimeter now. Test for 0.6 ohms max across each position.
12. Put it all back together again and re-connect battery.
13. Watch in awe as windows go up and down when you want them to. :D :D :D
redwards
Postby redwards » Wed Mar 26, 2008 8:22 pm
Thank you, manga blue! That's one for the file...
Former owner of a white 1994 NA8 Clubman
Locutus
Postby Locutus » Thu Mar 27, 2008 12:10 am
spraying some silicon lubricant along the window tracks also helps speed things up considerably.
Re: NA window speed fixed!
Postby Okibi » Thu Mar 27, 2008 12:15 am
manga_blue wrote:.. 8. Clean each contact with metho then polish lightly with about 800 wet n dry.
I seem to remember reading somewhere that you should coat the bare metal with something like this:
http://www.altronics.com.au/index.asp?area=item&id=T3064
Garry
Postby Garry » Thu Mar 27, 2008 8:32 am
Enjoy it while it lasts. It wont be long till the contacts are carboned up again. But at least you know how to clean the contacts now.
Postby manga_blue » Thu Mar 27, 2008 10:57 am
You're probably right about it gumming up again. Next time I'll try running silver solder onto the contacts.
tjcool
Postby tjcool » Fri Mar 28, 2008 12:57 pm
yeah the black up again quick smart
tried solder but had a lot of issues trying to find the right flux to stick the solder to the copper contacts
anyone know what i was doing wrong there ?
sh*t solder?
sh*t solderer?
leave the gun.... take the canoli's
tjcool
yeah they black up again quick smart
sh*t solder?
sh*t solderer?
Postby manga_blue » Fri Mar 28, 2008 1:32 pm
Thinks ... maybe if we ran a relay across the switch we would reduce most of the current across the contacts.
Anyone care to sketch a wiring diagram for that which would work with one relay? Or do we need 4 relays, one for each output wire?
Wuey
Postby Wuey » Fri Mar 28, 2008 11:21 pm
tjcool wrote:yeah they black up again quick smart
sh*t solder?
sh*t solderer?
I'm afraid you belong to the second category. Solder sticks to copper like flies stick to sh!t. The trick is to clean the contact well, a little bit of very light sandpapering will help a great deal. A final touch is to rub the contact with cotton wool soaked with methol to remove any traces of finger grease. Clean your iron tip with a piece of wet rag after it has reached operating temperature to remove old traces of solder. Then tin your iron with just a bit of solder first, then apply heat onto the contact, feed the solder against the iron tip and let the solder flow onto the contact. I suggest you practice with a piece of copper scrap or stripped copper wiring first.
Oh, normal lead solder isn't that crash hot for this job. Lead-free solder works much better against oxidation than leaded solder.
Image 2004 SE
tjcool
Postby tjcool » Mon Mar 31, 2008 9:17 am
thanks wuey
Fatty
Postby Fatty » Wed Apr 02, 2008 2:25 pm
here is another way to fix those pesky little electric window gremlins...
saves a few precious kilos this way too :)
Postby manga_blue » Wed Apr 02, 2008 4:21 pm
Fatty wrote:here is another way to fix those pesky little electric window gremlins...
You're just showing off the fact that you still have one doorskin intact. :D
Postby Okibi » Wed Apr 02, 2008 10:50 pm
looked better with the vicegrips :mrgreen:
green_comet
Car Detailing Guru
Postby green_comet » Thu Apr 03, 2008 1:00 am
Okibi wrote:looked better with the vicegrips :mrgreen:
:shock: hahahaha...
I just ordered a couple Momentary (on)off(on) toggle switches to replace my power window switch. Ill be wiring them up in a week or two, so ill post up how they go.... very easy to wire them up, and they will go with the retro look im after. :D
Going to be similar to the Nielex setup but not mounted like that..
They are going into the carpet centre console im making.. 8)
