RCA Cable route? PICS PAGE 3
- ducktape69
Hi all,
where's the best and easiest route to run the rca cables/remote turn on wire from the headunit to an amp in the boot?
Sam
Sam
- green_comet
- Car Detailing Guru
- ducktape69
- Ajay
- PASHN8
Yep, passenger side here as well
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- ducktape69
green_comet wrote:mine runs under the centre console, then under the rear firewall carpet behind the drivers seat, and into the boot via a hole that is in the firewall.
Yup same here, if you're really slack you don't need to take off the center console and can just poke them up under one side
- ducktape69
wouldnt it be better to run the cables on the passenger side as not to get close to the battery cables on the driver side boot?
is the hole in the passenger side firewall same as driver side firewall?
X2.
Get some decent shielded RCA's and you won't have a problem with sound from the car electrics anyway.
- Russellb
- RIP Nov 2014
NMX516 wrote:[
X2.
must get around to this on mine. the alernator nosie is NOT COOL
FYI mine is under the center Console and then around to the battery Area to the Amp.
My ClubmanRebuild
MX5 SE Rally car is HERE
- Alex
- ducktape69
bought some nice shielded RCA cables and remote wire cabling today...
will chuck it in saturday hopefully...
anyone have any experience if the hole in the firewall in passeneger side is easier or better to get through then driver side (and if battery 'noise' affects cabling on driver side)???
- ducktape69
