Can you identify this part?
SKYHI
Postby SKYHI » Thu Mar 13, 2008 9:34 am
Hi guys,
I actually have two questions, both relating to the removal of air conditioning from my NA8.
Firstly, whilst removing one of the rails that run down the drivers side I came across what looks like a sensor of some description that was connected to a wiring loom. These parts are located just behind the drivers side headlight. Apart from this sensor the wiring loom also goes to the fan for the AC and these two weird looking things covered in rubber (picture below). Does anyone know what these are, and can I leave them off the car if I'm completely removing the AC?
Secondly, I disconnected two coolant lines that run off the back of the engine and through the firewall to the heat exchanger / evaporator thingy under the dash. With the AC removed do I now just connect these two coolant lines together effectively bypassing the unit that was under the dash?
Cheers, Paul.
Cal
Postby Cal » Thu Mar 13, 2008 11:51 am
Nah dunno, mine had no A/C.
SKYHI
Postby SKYHI » Thu Mar 13, 2008 11:53 am
Mine doesn't either..........now
Thanks for your help :P
Postby bruce » Thu Mar 13, 2008 12:24 pm
Not airbag related? (Certainly hope not!)
Juffa
Postby Juffa » Thu Mar 13, 2008 12:25 pm
Can't answer the question on the electrical plugs.....
On your other question. By coolant I assume you mean radiator coolant? If so, and you bypass the heater core you will not get any heat into the cabin (Even Brisvegas can get cold), whcih could be an issue if you need to defrost/clear the windows.
J
SKYHI
Postby SKYHI » Thu Mar 13, 2008 12:27 pm
Not really a concern as it's destind to be a race car. Anyway I can just take out a couple of grommets out of the firewall and let the hot air from the engine bay into the cabin :D
Paul.
Steampunk
Postby Steampunk » Thu Mar 13, 2008 2:37 pm
I've got them, I know where they sit, and I have AC.
Was that any help at all? :|
Definitely not airbag or ABS. Does your clubie have power steering? If so, does it still work? :mrgreen:
brenno
Postby brenno » Thu Mar 13, 2008 2:53 pm
I had AC retro fitted to my NA8 and these were identified as relays that were needed for the install.
White NA8
SKYHI
Postby SKYHI » Thu Mar 13, 2008 3:03 pm
brenno wrote:I had AC retro fitted to my NA8 and these were identified as relays that were needed for the install.
Thanks brenno. The way it was all hooked up on the same loom I figured it had to be something to do with the AC.
Paul.
vak82
Postby vak82 » Fri Mar 14, 2008 2:02 am
I'm not very technically minded but I remember seeing that on my 91 Astina. Could it be the motor for the retractable headlight?
NA6T = Playtime | NC = Snooze
Steampunk
Postby Steampunk » Fri Mar 14, 2008 8:49 am
Nope Vak, I thought the same too initially, but the headlight winder motor thingy is much bigger. The cap is similar though.
