2002 fog light issue
AJ
Postby AJ » Sat Feb 23, 2008 2:59 pm
check your connections then??? :?
XMX5 Rogues
Postby Mr Morlock » Sat Feb 23, 2008 5:41 pm
Your \"lamp\" is only housing and lens- the globe is the light source and the wires connected to it provide the electrical connection. All probability is a bad connection. I have seen some posts which advise easiest way to get access.
wun911
Postby wun911 » Sat Feb 23, 2008 5:47 pm
Easiest way is to take the front wheel off,
Take the plastic cover off the wheel arch.
Push the plastic cover to one side (its thin and flexable) and thats it and you will see the connections on the back of the fog lights.
I was suprised how dirty it was inside there... The globes are quite cheap about 5 dollars.
every ounce counts
Casey
Postby Casey » Sun Feb 24, 2008 9:28 am
What is expensive is the lamp unit themselves. The lens is actually made of glass, and quite a few have been broken by flying stones.
Next time you are at the auto shop get some of that self-adhesive headlight protector material (a thick, clear vinyl) and stick a piece on each lamp. Clean the glass with some metho or prepsol first.
You can cut it with a pair of scissors, and I used a roll of masking tape as a cutting template.
White SP Image
chatchat
Postby chatchat » Sun Feb 24, 2008 2:47 pm
if the whole unit, cost u around $400+, but if it works on and off, obviously no problem to the unit.
I have taken out the light b4, just turn all the wheel to one side, take out 3 or 4 plastic clip to open the guard and u should able to access the fog light.
Postby Hammer » Sun Feb 24, 2008 3:41 pm
mxroadster, do you know if the foggies on your 5 have been fixed as a result of the recall (sometime in 2003)?
It had to do with some tension spring to the fog lights. It prevents them vibrating too much and resting on the plastic bar (which can cause some softening of the surrounding bumber aperature or worst - fire).
They placed a sticker somewhere near the drivers side (inside) door frame) if they have.
wun911
Postby wun911 » Sun Feb 24, 2008 4:31 pm
Im lucky Ive never had my lense broken touch wood. Where did you get the clear vinal from?
every ounce counts
Postby Hammer » Fri Feb 29, 2008 5:37 pm
Casey wrote:You can cut it with a pair of scissors, and I used a roll of masking tape as a cutting template.
Good idea! I might just do that.
Casey
Postby Casey » Sat Mar 01, 2008 3:56 pm
wun911 wrote:Im lucky Ive never had my lense broken touch wood. Where did you get the clear vinal from?
It's sold as a universal headlight protector kit - sold in Auto One and Supercheap type of places.
White SP Image
Craig
Postby Craig » Sat Mar 01, 2008 6:08 pm
Wasn't there a TSB on the foglights? :?:
