dodgy turtle paced electric windows
tjcool
Postby tjcool » Fri Feb 15, 2008 3:24 pm
howdy y'all
has anyone had any experience with replacing power mirror motors on the NA6 ?
I have cleaned and wire brushed the copper contacts under the buttons in the centre console to give it a better contact (which made a big difference worht trying if you are having similar issues) but now a while later the passenger side window especially is so slow and some days gets stuck like 3/4 of the way down.
I remember reading somewhere on here i think about people lubing the window itself with silicone or some sh*t ?
is this worth giving a try or should i just get a new 2nd hand motor ?
any ideas or expert advice would be appreciated thanks
leave the gun.... take the canoli's
Nickers
Postby Nickers » Fri Feb 15, 2008 3:53 pm
Your window motors might just be overworking...
The rubbers along the outside of the door, between the glass and doorskin itself on mine have hardened with age. This puts pressure on the glass as it slides up and down (more down than up due to the design of the rubber), slowing the glass down quite a bit. Leave the car in the sun, let these rubbers heat up and become a little more flexible, then try the window again. If it is quicker, your rubbers are shagged.
Anyone know if there are replacements available?
1990 Red NA6
sabretooth
Postby sabretooth » Fri Feb 15, 2008 6:20 pm
I found that removing, cleaning completely and lubricating the rails/guides with silicone spray did the trick nicely.
TieNN89
Postby TieNN89 » Fri Feb 15, 2008 7:05 pm
i got some CRC Tac 2 from Repco sprayed it on the window rails and it worked good
when I got the car the windows went up very slow compared to now
timk
Postby timk » Fri Feb 15, 2008 8:30 pm
You could get an NC, their windows wind so quickly! :cry:
ma64rk
Postby ma64rk » Wed Feb 20, 2008 1:22 pm
\"remember reading somewhere on here i think about people lubing the window itself with silicone or some sh*t ?\"
I'm not sure about using sh1t :P , but I have tried silicone spray and it is a simple fix. :)
Take the road less traveled...
Silver 01 w/hardtop & stylebars...
tjcool
Postby tjcool » Thu Feb 21, 2008 8:44 am
thanks all ill give the silicone a go
