Meter fuse blowing
Gazbo
Meter fuse blowing
Postby Gazbo » Tue Jan 22, 2008 4:42 pm
My meter fuse has blown twice in the past six months.
Might be just bad luck, I can't see any reason for it to blow (it's 10A), just the tacho, fuel/oil/temp gauges, indicators, charge lamp and brake fail lamp run off it.
Anyone else had fuses blow regularly?
(I have a Rhino immobiliser connected that flashes the indicators... anything after-market would be first suspect...)
JBT
Postby JBT » Tue Jan 22, 2008 6:14 pm
Check wiring to the immobilser or any other in car add-ons would be the first place to start.
muzza2
Postby muzza2 » Tue Jan 29, 2008 6:51 pm
im having the same problem
so when you find out what it is, let me know
i've got a 1990 mx5 which i've replaced this one fuse about 4 times now...
i dont have any mods ect, and no imob.
sabretooth
Postby sabretooth » Fri Feb 15, 2008 10:43 pm
I'd check the wiring on that immobiliser, and perhaps anything that's on that circuit. There could be a short somewhere.
