HORN WON'T STOP BEEPING AFTER BATTERY CHARGE
Rooster
Postby Rooster » Wed Jan 16, 2008 4:06 pm
I had to recharge my battery. When I reconnected the battery the horn would not stop beeping, The Motor will start but I can't stop the beeping. What am I doing or have done wrong?
Please help :oops: :oops:
JBT
Postby JBT » Wed Jan 16, 2008 4:08 pm
Do you have an alarm that could be causing the problem?
Rooster
hHORN BEEPING AFTER BATTERY RECHARGE
Postby Rooster » Wed Jan 16, 2008 4:18 pm
Car is a standard 2002 as far as I know
Benny
Postby Benny » Wed Jan 16, 2008 4:30 pm
Just drive it.
Everyone will think you got it for Xmas. :mrgreen:
Ajay
Postby Ajay » Wed Jan 16, 2008 7:47 pm
auto-elec
or
take out the horn fuse until you fix it
Alex
Postby Alex » Wed Jan 16, 2008 9:48 pm
Relay??
Rooster
Horn beeping after battery change
Postby Rooster » Thu Jan 17, 2008 7:45 pm
I failed to mention that besides horn beeping the hazard lights were flashing.anyhow I took the advise and removed the horn fuse, after connecting battery, the flashing started again. this continued for approx 20 seconds and the stopped for 5 seconds, and restarted again, this continued for about 4-5 times and then everything returned to normal. Thanks for your suggestions.
Rooster
Ajay
Re: Horn beeping after battery change
Postby Ajay » Thu Jan 17, 2008 8:34 pm
Rooster wrote:I failed to mention that besides horn beeping the hazard lights were flashing.anyhow I took the advise and removed the horn fuse, after connecting battery, the flashing started again. this continued for approx 20 seconds and the stopped for 5 seconds, and restarted again, this continued for about 4-5 times and then everything returned to normal. Thanks for your suggestions.
Rooster
so is the problem all fixed now?.. or did you just take out the fuse?..
Ajay
Rooster
Horn won't stop beeping after battery charge
Postby Rooster » Fri Jan 18, 2008 8:20 pm
After hazard lights finale stopped flashing I replaced horn fuse and all was back to normal, at last :oops: :oops:
Thanks
Rooster
Postby bruce » Sat Jan 26, 2008 11:55 am
Sure sounds like you have an aftermarket alarm fitted (possibly no siren but just uses the horn).
Look under the steering column area and see if you can see a black box dangling there?
Rooster
HORN WON'T STOP BEEPING AFTER BATTERY CHANGE
Postby Rooster » Tue Jan 29, 2008 8:30 pm
Bruce
:oops: Sorry about being late in answering your suggestion but I have been away for a few days,
I couldn't find the black box under my steering wheel, but I found in the papers I received when I purchased the car a small book titled \"FACTORY ALARM UPGRADE\", which I take it is the Alarm you referred to. After reading book I hope I will know what to do next time,
Thanks a heap.
Rooster :oops: :oops:
