Dash lights not working
Posted: Thu Jan 03, 2008 9:35 pm
by sweep77
i'm sure i've checked all the fuses and seem to be fine. everything works except the dash lights aren't coming on. any ideas?
Posted: Thu Jan 03, 2008 10:29 pm
by JBT
Which model? Check the dimmer rheostat.
Posted: Thu Jan 03, 2008 10:57 pm
by sweep77
95. dimmer reostat? is that behind the dimmer switch?
Posted: Thu Jan 03, 2008 11:25 pm
by JBT
It's the dash lights dimmer thumbwheel thingy.
Posted: Fri Jan 04, 2008 12:39 am
by SuperMazdaKart
hrmm, headlights are on too?
Posted: Fri Jan 04, 2008 12:43 am
by TieNN89
are you tail lights working?
i'm not sure with the mx5 but i remember when my 121 dash lights went out my tail light didn't turn on either
result blown tail light fuse
Posted: Fri Jan 04, 2008 7:26 am
by sweep77
yeah checked the dimmer but makes no diff. all the other lights seem fine. headlights work, just the dash lights stopped working. are they part of another circuit?
Posted: Fri Jan 04, 2008 8:21 am
by JBT
It looks like power comes to the light cluster through the \"tail\" fuse. If the heater controls and ash tray lights work, then you may have a dislodged or broken wire to the light cluster.
Please let us all know what you find.
Posted: Sat Jan 05, 2008 7:31 am
by sweep77
thanks. i put a cd player in and i think i've earthed it to the wrong part so it keeps blowing that fuse. i'll have a look tonight.
Posted: Sun Jan 06, 2008 10:32 am
by sweep77
All fixed. theres a red/black wire that goes to the standard tape deck which i thought was a negative which i had hooked the cd player earth up to. removed it and earthed somewhere else and works all good now. Thanks for that wiring diagram!
Posted: Sun Jan 06, 2008 11:43 am
by JBT
Glad you got it sorted.
Re: Dash lights not working
Posted: Sun Nov 10, 2013 8:18 pm
by dinknjim
Sorry to grave dig here guys.....
I've put a new h/u in recently too and lost my dash/ac lights...
What did u end up doing with the red/black wire that goes to the stock tape deck?
Posted: Sun Nov 10, 2013 9:26 pm
by TieNN89
dinknjim wrote:Sorry to grave dig here guys.....
What head unit did you fit?
The Red/Black wire should be the dimmer wire on the NB8A which you don't really need to hook up but if you don't hook it up to your headunit (if it has that wire to hook up) then when you turn on your lights the head unit won't dim
I'm not sure why you've lost your dash/ac light thought unless it shorted out on something and blew a fuse
Posted: Mon Nov 11, 2013 1:36 pm
by dinknjim
The h/u I used is an alpine 117E, couple of years old now but still nice.
The wiring diag that I was working off had 2 wires as the interior lights, the red/black and a grey/red wire. i'll have to check the fuses today.
still have tail lights tho, so not too sure which fuse to check... looks like theyt are all on the list.
Posted: Mon Nov 11, 2013 2:49 pm
by dinknjim
dinknjim wrote:The h/u I used is an alpine 117E, couple of years old now but still nice.
Fixed
red/blk goes to h/u. while the grey/blk wire need to be earthed
