Posted: Wed Dec 12, 2007 11:53 am
Ok, so assuming you have a Mazda imported MX-5 and not a personal import/Eunos Roadseter (they can have sealed beams).
Raise the headlights (push button in dash above radio)
Remove the black plastic surrounds from each headlight (2 or 3 screws each side)
you should now have access to a black metal ring that retains the headlights.
There are 3 small screws that should be loosened (not removed).
Once the screws are loose you should be able to rotate the ring slightly, lining up the 3 screws with holes that allow the headlight to be removed.
With the headlight in your hand you will need to take the electrical connection off the back. You will need to press/squeeze in a retaining clip (been a while since I have had to do this) to release the connection.
With the electrical connection off you can remove the rubber dust/water boot. Note how it was mounted so you can return it to its original position.
You should now see the H4 bulb, it is held in by a spring loaded metal clip. Release the clip to free the bulb.
Note: do not touch the bulb with your bare fingers when inserting the new one. Oil on the blub will greatly reduce the bulbs lifespan
Installation is a reverse of the above.
J
J
