Whats this loose connector under my dash board?
Bevan
Postby Bevan » Wed Oct 31, 2007 1:25 pm
That looks like the drivers door buzzer, and believe me, it is the best mod the previous owner did to your car.
If you want to re-connect it, the other end is to the left of the steering wheel, hard up against plastic trim.
Alex
Postby Alex » Wed Oct 31, 2007 5:14 pm
what he said ^^^
you should be able to find the other side of it right up against the steering column wiring,
basically it prevents a buzzer from sounding if the key is in the ignition and the door is open, it's alright at first then it just gets annoying
