Boot Light ?
ducktape69
Boot Light ?
Postby ducktape69 » Fri Oct 26, 2007 10:34 am
the boot light stopped working when i open the boot...
i had a quick look last night and can see the plastic cover can slide over but wont come off...
what should i be checking?
how do i take out the cover to check the bulb?
Sam
Ajay
Postby Ajay » Fri Oct 26, 2007 10:55 am
be thankful you have a boot light :lol:
sorry i cant help you
Garry
Postby Garry » Fri Oct 26, 2007 11:00 am
Does it work when the parking lights are on?
According to the owners manualy you slide it in the direction of the arrow and it pops out. But I didn't have any luck getting mine out, but then I didn't try very hard.
ducktape69
Postby ducktape69 » Fri Oct 26, 2007 11:18 am
havent checked if it works with the parking lights on...ill check tonight...
only started yesterday after getting it back from getting my boot/bumper repsrayed from my little truck incident months ago.
what could they have missed ? all the plugs seem plugged in and fine from my little inspection yesterday.
Garry
Postby Garry » Fri Oct 26, 2007 11:31 am
Is it plugged into the switch?
Postby bruce » Fri Oct 26, 2007 12:13 pm
Is the switch mounted correctly (as the panel beaters may have removed it to paint).
ducktape69
Postby ducktape69 » Fri Oct 26, 2007 1:16 pm
whats this switch?
i can see the wire is plugged in...
Garry
Postby Garry » Fri Oct 26, 2007 3:40 pm
The switch is attached to the boot lock. If you look behind the trim at the rear of the boot you'll be able to see it
ducktape69
Postby ducktape69 » Fri Oct 26, 2007 4:31 pm
ahhh
thanks garry!
what does this switch look like? ill have to have a look when im home...
Stu
Re: Boot Light ?
Postby Stu » Fri Oct 26, 2007 5:49 pm
ducktape69 wrote:the boot light stopped working when i open the boot...
Sam
Slide and pull down a bit, its quite hard to get out, comes out at about the same moment you think you are going to break it
ducktape69
Postby ducktape69 » Sat Oct 27, 2007 12:03 pm
well i pried out the light case with a screwdriver and turns out both LED's are blown....weird...
time for some LED's
