Wiring Diagram
Stu
Wiring Diagram
Postby Stu » Fri Oct 26, 2007 12:36 am
Anyone know where I can get a copy of the wiring diagram for an NB8B?
Andrew
Postby Andrew » Fri Oct 26, 2007 9:19 am
Will an NB8A be ok :?:
Stu
Postby Stu » Fri Oct 26, 2007 1:08 pm
Thanks Andrew, for what I require the NB8A wiring diagram should do.
Andrew
Postby Andrew » Fri Oct 26, 2007 1:13 pm
Stu
Postby Stu » Fri Oct 26, 2007 1:17 pm
Thanks mate.
Andrew
Postby Andrew » Fri Oct 26, 2007 1:20 pm
No worries 8)
Stu
Wiring Diagram
Postby Stu » Thu Sep 04, 2008 2:24 pm
Nark wrote:Awesome!
I'm doing a head unit install. Any ideas whether the audio wiring diagram changed between NB8A and NB8B?
I ended up getting the radio adapter harness from Mx5parts.co.uk. It cost maybe $20, saved time and the OEM wiring harness. Mania may have this part in stock as well.
Incognito's write up also used this harness
Stu
Wiring Diagram
Postby Stu » Tue Sep 09, 2008 2:30 pm
It looks exactly the same as mine.
I ended up going for a stereo -> oem plug which then plugged into the oem -> mx5 cable from mx5parts. I'll try and take some shots tonight of the cabling and connectors.
Wiring Diagram
Postby bruce » Tue Sep 09, 2008 5:32 pm
Just visit your Repco/Stupid-cheap and get them to order one.
