Hi lads,
Just recently installed a Sony Xplode unit (thanks mx5_boy).
I'm now looking at upgrading my speakers in the doors and adding some in the head rests (relative noob when it comes to audio)...will later hook up amps & subs, but want to nut out the 1st few sets of speakers.
So any recommendations other than factory?...not wanting little 5 watters in the headrest either, but something small enough to go in the headrests that won't require large amounts of foam cutting.
Once I've got this nutted then it's onto the amps and some doof doof. ;)
All the ones I've seen for the doors with covers seem a little too modern to the look I'm after (like suttle changes). Any feedback is good feedback.
Ta,
CS
speaker recommendations
- Captain Spank
- Mactype
- Captain Spank
A number of us have 6.5 inch (16cm) speakers mounted in the doors. I have Jaycar spilts, with the separate tweeter mounted on the upper padded section of door.
http://www.jaycar.com.au/productView.as ... BCATID=602
- DOYLMX5
- Vehicle: ND - 2
I have seen the Pioneer cyclones (6.5\" splits) I think they are called used in a few different application and they go really good.
Loud, hard and really clear. can get them for about $200 for the pair.
They also slot straight in with no cutting or bending required, the original plastic cover can just go straight over the top too.
On the other hand if bass isn't a problem as you would be getting more stuff later ;), I swear by the MB Quarts. 6.5\" German made quality.
Some modding of the holes required as the back of the speakers are a bit bigger, not fitting in the holes properly. You would not be dissapointed with these. More expensive though, about $350 for the most basic pair.
As for the smaller speakers, any old 4\" will fit into the head rests.
I got some eclipse 4\",2 in each headrest. $160 for a pair though
Just get some 4\" speakers from Jaycar, they aren't as important anyway.
When you get into amps, the ones from Jaycar are really good value for money, but that is for later.
Hope this helps, I have fiddled a lot with my stereo. Still doesn't sound just how I want it.
Good luck matey
Good luck matey
- Benny
Personally speaking, the best sounding speakers that fit in the doors are the Focal splits, but at over $1,200 a set, they are exxxy.
If you are changing the speakers in your doors, take the time to waterproof them, or you may find you wil have to change them when it rains heavily.
- Captain Spank
- rain902
i put rockford fosgate baby ones (3 inch i think) in the NA headrests - fantastic. around $120 a pair.
i like a bit of high end (frequency, not products), so i jammed jaycar tweeters on the top of the doors to replace the stuffed alpines that were in my car when i bought her - i love the brightness they cast across the cabin. well worth it imho
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- Captain Spank
- muzzy66
Benny wrote:Personally speaking, the best sounding speakers that fit in the doors are the Focal splits, but at over $1,200 a set, they are exxxy.
The Focal 165K2P sound brilliant at $849rrp, however still not cheap!!
On a lower budget, there is some decent stuff around.
* Hertz HSK165 - $360rrp
* Morel Tempo 6 - $265rrp
* Rainbow SLC265 -$XXX (not sure of RRP)
Each is a nice sounding speaker for the money!
If the budget is still a little high, then the Jaycar splits offer probably the best cheap sound at around $150.
