Head Unit install
- corners
- Vehicle: ND - Supercharged
Head Unit install
hey all
I installed a headunit into my JDM mx5,
I wanna know where i can get a pocket to fill the gap below as the headunit is only single din.
Thanks
Jaron
Thanks
Jaron
- jules
- Guitar Hero
- jules
- Guitar Hero
- jules
- Guitar Hero
- corners
This is my current installation.
Do I need to change the surround or can I simply buy and fit a pocket without any gaps?
http://gallery.zooked.com.au/gallery2/m ... d.JPG.html
Thanks
Thanks
- meanmx
You don't have to change the facia if you don't want to in which case you have to get the pocket that manga had a link to or you could use a normal din size pocket and find something to fill the gap. But as Jules said the later model fasia is much better and that is what I have done to my car. Think from memory it is about $85? or so from Mazda but you have to make sure you get the later model one from 97 I think. Fits 2 din size spaces perfectly and it looks properly installed.
Ben
Ben
2014 VW Mk7 Golf R
- PUR157
meanmx wrote:You don't have to change the facia if you don't want to in which case you have to get the pocket that manga had a link to or you could use a normal din size pocket and find something to fill the gap.
The latter is what I did in my car... I just used the stock 0.75 (whatever size) DIN pocket and glued a piece of black plastic from a foolscap folder above it
I guess I can't say it looks as neat as a 2 DIN size fascia filled up properly
But I did this out of necessity rather than whether or not it looked any better
You will however find that your head unit may even fit better in the updated fascia... you can see the gap around the border of the faceplate of the head unit on my install
hope this helps!
Oneness of Man and Machine
- meanmx
Which pocket are you after? The din size pocket where you have to fill the gap is available at most automotive stores as it is a standard size. Or the larger than normal pocket that fills the gap for you is available from mx5parts.co.uk (click the link that manga kindly provided) or I've heard a rumour somewhere that mania might stock them. Hope that helps.
Ben
Ben
2014 VW Mk7 Golf R
- meanmx
The uk website is a brilliant place and once you register and put it in your cart they will tell you the cost of postage before you pay anything and then you just convert over to aussie dollars. I can't stress enough how good mx5parts.co.uk are. You'll receive it generally in about 4 working days.
Ben
Ben
2014 VW Mk7 Golf R
