Hardtop Demister question Help needed from auto elec. guru
Postby Okibi » Fri Oct 12, 2007 3:43 pm
Have you checked the fuse?
Can you check if you have a current with a multimeter?
Postby Okibi » Fri Oct 12, 2007 7:29 pm
I seem to remember the defroster automatically turns off if the soft top is down. I run my hardtop over winter here so i'm not 100% sure.
Perhaps it's thinking the soft top is down and therefor turning off the defroster wiring (that you're using for the hardtop)/
Andrew
Postby Andrew » Mon Oct 15, 2007 4:41 pm
I have the wiring diagrams for an NB somewhere.....
Troy, to have a PM.
Andrew
Postby Andrew » Tue Oct 16, 2007 10:51 am
No problem 8)
