crackling/static with new headunit install
ducktape69
Postby ducktape69 » Tue Sep 11, 2007 4:05 pm
getting crackling/static/distortion from both speakers when sound turned up(even with no bass at all).
i done all the wiring properly...
and doesnt seem to happen with the radio..
and ideas?
Sam
Fuzzlet
Postby Fuzzlet » Tue Sep 11, 2007 4:57 pm
Whats the other source unit? Is it an ipod adapter? CD stacker? CD in unit?
Ipod adapter - sounds like you have a dodgy connection somewhere, otherwise I'm not sure. Keep the cable away from power cables
CD Stacker - As above
CD in HU - Have you tried other CDs? If so, and it still does it, perhaps the lens of the reader is dirty. Most cd shops sell cleaning kits
ampz
Postby ampz » Tue Sep 11, 2007 6:56 pm
did you replace the speakers?
If not it could be buggered cones :oops:
you need to give us some more info, it sounds like maybe a short from one of your speaker sources, static could be an insufficient ground.
Huh?
Fuzzlet
Postby Fuzzlet » Tue Sep 11, 2007 9:38 pm
Just re-read ur post...Are the speakers still original? If so thats the problem. They'll be distorting, because they cant handle much power
Ajay
Postby Ajay » Tue Sep 11, 2007 9:47 pm
your not running an amp are you?.. just off the headunit.. if so see fuzzlets post above :D
ducktape69
Postby ducktape69 » Wed Sep 12, 2007 10:51 am
i spent 30min checking the wiring yesterday and couldnt see anything wrong...
SO...i decided to rewire it again by removing the factory harness altogether and that has actually fixed the problem.
BTW, its the Alpine iDA-X001 i bought from bush_pig on this forum, so no cd's at all...just ipod/usb...LOVE IT!
ducktape69
Postby ducktape69 » Thu Sep 13, 2007 6:52 pm
static started to come back today surprisingly but not as bad.
only connection is a direct ipod cable. happens with radio also i found.
very weird...
ducktape69
Postby ducktape69 » Sun Sep 16, 2007 1:17 pm
well finally spent a bit of time rewiring the whole damn thing.
ended up being something so simple...a couple of the unused wires from the headunit were touching....
ARGHHH..last place i looked.
well at least its fixed now.
