Hi guys,
I was trying to lock my car (NB8B) with the remote this morning, the light flashes as usual but it won't lock. It doesnt even make any sounds.
When I tried using the key to lock it, it also won't lock both doors.
Any clue???
Cheers.
Remote Central locking problem?
- AB7
- Benny
First, check the fuse, then if that is OK, you will have to pull the the inside cover off the driver's door and check the wiring etc.
I think the central locking works off the driver's door, so that is probably where the problem is if it's refusing to work and the fuse is OK.
i also have this problem, it started doing it when my alarm stopped working
- metris
- Vehicle: NA6 - Turbo
same here, try jiggle the wiring nearest the accelerator pedal under the dash and see waht happens...
my problem is definately connected to this area of wiring as when i jiggle it my doors lock or unlock on me, or the immobiliser or alarm kicks in...
pain. in. arse.[/quote]
NA6 turbo cute scary fun machine!!
I had a central locking fuse blow under the dash when I was wiring up the boot release.
Remove the plastic panel below the steering wheel (2 philips head screws)
Look at the fuse holders along the wires near the steering column, you've probably blown one of these.
