Replacement antenna for NB
BlackMX
Postby BlackMX » Sat Aug 04, 2007 8:38 pm
Has anyone replaced the power antenna with a fixed mast unit like the ones on S2000 and NC (would this fit an NB)?
I've replaced my HU but the new one doesn't have an antenna control.If it's turned on the antenna goes up and to my mind I really don't like the look of it up...spoils those curves :P
So if someone has any idea where to source one and the approximate cost this would be highly appreciated..
Oh and to the Wingzzz guys up north,,,Bastards. :D
I now have another addiction and a deep fryer (something I swore I would never own!!)
NB SE
AJ
Postby AJ » Sat Aug 04, 2007 9:27 pm
we did an interesting test at the dodgy detail day here blackmx...............young saboteur unscrewed his NA6 remote control antenna off his NA & unscrewed the little black whip off our NC, the threads are exactly the same, which surprised us, the RC antenna screwed straight into the NC base, unfortunately the NC antennas thread was too short to screw into the NA base, but they were essentially the same, we just sat the NC whip into the NA base & it looked awesome...............i guess what i'm saying is, just try it in the NB, it fits the other 2 models :mrgreen:
XMX5 Rogues
marcusus
Postby marcusus » Sun Aug 05, 2007 1:31 am
I've been contemplating this as well... I replaced the head unit and didn't connect the antenna wire to anything. I listen to CD's the majority of the time, so it didn't make sense to wire the antenna to the power etc.
Occasionally I tune in to the radio for some FBi goodness, but of course FBi being such a small station, you don't get good reception unless the NB antenna is properly retracted.
If I could get my hands on a small NC style mast, I'd love to give it a burl.
BlackMX
Postby BlackMX » Sun Aug 05, 2007 12:14 pm
Quite a few on the forum have done this with the S2000 antenna and apparently it fits very well however the thing costs just over US$100!....wonder what they cost here? Come Monday I'll give Honda a call.
Thanks AJ I will call Mazda too!
Did find this though http://www.locustom.com/miata_fender_install.htm
This I would go for.
NB SE
Andrew
Re: Replacement antenna for NB
Postby Andrew » Sun Aug 05, 2007 1:03 pm
BlackMX wrote:I've replaced my HU but the new one doesn't have an antenna control.If it's turned on the antenna goes up and to my mind I really don't like the look of it up...spoils those curves :P
I had the same issue when i installed my head unit.
My solution was to install a switch to control the power going to the antenna giving me the choice when it goes up and down.
Head unit on, antenna stays down no matter what function is selected ie: CD, radio.
Press button when head unit is on antenna goes up... :)
marcusus
Postby marcusus » Sun Aug 05, 2007 1:14 pm
Yeah, I thought about doing something like that, but I never really followed the thought all the way through.
How easy was the fabrication of the button bits? The electricals would be easy enough to do myself... just a contact closure type button I would think.
Andrew
Postby Andrew » Sun Aug 05, 2007 1:22 pm
Very easy, push on, push off button from Jaycar, short section of wire soldering iron, drill, knife and about 10 minutes.
marcusus
Postby marcusus » Sun Aug 05, 2007 1:28 pm
So I'm guessing you drilled the hole through the existing spare button and just glued it on or something to that effect?
I wonder how easy it'll be to make the entire spare button pressable... shouldn't be too tricky I'd think... Might have to get in behind there on a spare weekend and have a fiddle.
Andrew
Postby Andrew » Sun Aug 05, 2007 2:04 pm
Yes drilled a hole on the switch blank the correct size and tightened up the nut on the back of the switch.
You could purchase a real switch to fit in there from Mazda or Ford but i'd hate to think how much they would cost :shock:
marcusus
Postby marcusus » Sun Aug 05, 2007 2:14 pm
Andrew wrote:You could purchase a real switch to fit in there from Mazda or Ford but i'd hate to think how much they would cost :shock:
I was thinking of just seeing if you could loosen the current blank one, and just put a toggle behind the current one.
Something to think about for another weekend though. At least I know now it'll be relatively easy if I want to do something similar to what you've done Andrew :)
Bevan
Postby Bevan » Sun Aug 05, 2007 9:21 pm
Just buy a JVC headunit. All of their decks have the antenna switch. 8)
BlackMX
Postby BlackMX » Sun Aug 05, 2007 9:53 pm
Bevan wrote:Just buy a JVC headunit. All of their decks have the antenna switch. 8)
You're only saying that because JVC's light up BLUE!! :lol:
NB SE
marcusus
Postby marcusus » Sun Aug 05, 2007 9:54 pm
Well, the old Pioneer deck works pretty well, and already does everything plus more than the standard NC stereo even, so not really worth replacing it til it carks it. That being said, the screen is on the way out because I used to remove it when it was installed in my own car for security. Of course, the removeable face security feature doesn't stop me from dropping it :oops:
That and I really doubt I'll bother buying a new head unit if I get a new car... I'm getting too old to be dodging around with my cars...
RG.net
Postby RG.net » Mon Aug 06, 2007 8:13 pm
X2 8) 8)
RG.net
Postby RG.net » Mon Aug 06, 2007 8:14 pm
mine lights up red ... :mrgreen:
