NB speakers
- Fuzzlet
NB speakers
Had a measure of the speakers in an SE today, and they seemed to be around the 5 x 8 mark (or maybe 6 x 9). Who has changed their speakers, and what have you used?
- sprx3
- Garry
6x9 are to big, 5x7 or 6x8 will fit. As sprx3 has said, remove the plastic filler panel for the stock speakers and there is an 8\" hole there. I've recently replaced my scratchy Phillips 8\"ers with some Clearwater ones from the US with mixed results. Originally they were way to bright for my ears but with a bit of tuning they sound quite nice now.
- Fuzzlet
Yeah I noticed the plastic piece, and I might go down the path of SM, and use MDF to make some spacers....any chance u still have the templates?
- Alex
Fuzzlet wrote:Yeah I noticed the plastic piece, and I might go down the path of SM, and use MDF to make some spacers....any chance u still have the templates?
no real templates as such but u live close enough so we could just make up a new set.
Really easy to make, remove factory speakers, use paper or cardboard to make a template, trace it onto 3-6mm mdf, jigsaw it or in my case use scissors, match the holes on the template with the door then drill them onto the mdf (getting them in the right places was the hard part)
let me know if u need anymore help
- meanmx
SM wrote:or in my case use scissors
Ben
2014 VW Mk7 Golf R
- ampz
- Vehicle: NA6 - Turbo
- Fuzzlet
Yeah making a spacer out of MDF sounds the go, since I already have 6.5\" splits in the NA, and if I can transplant them into the SE it'll be nice
