Temperamental Radio?
Jimmy
Postby Jimmy » Fri Jul 06, 2007 9:21 am
I started the car up thismorning and turned the radio on while i scraped all the ice off the windscreen. got back in the car and turned the lights on and the radio turned off :shock: Turned the lights off and the radio came back on etc etc. Any suggestions. I was thinking fuse but they both are still functioning, its just one or the other.
Jimmy
Garry
Postby Garry » Fri Jul 06, 2007 9:31 am
Have a look on miatanet. This is a common problem with the US cars. There's a guy called Jeff Anderson that has a fix for it. But I cant remember what the fix was. It's either a dry joint or you need to bypass something with a jumper.
Jimmy
Postby Jimmy » Tue Jul 10, 2007 9:26 am
Cheers garry, found it on there alright. A great site. Will be consulting with it a lot more now. If anyone else has the problem with the radio not turning on when you want it to, heres the link for the fix:
http://www.miata.net/garage/radio.html
Jimmy
