NA headlight replacement
Shadow
Postby Shadow » Mon Jul 02, 2007 8:16 pm
well my NA is now blind in one eye. and sicne it has the sealed units (yes, import), i'm planning on bying a new pair of lights.
my question is, any suggestions from those whove been here done this before?
i'm looking at getting the newer style brighter ones (not blue though, pain in the arse to everyone else on the road).
are the H4 globes you see in the junkmail catalogues the same as the 4000k ones people have mentioned before? (can you tell i know squat all about lights :? )
and also are there any i should avoid completely?
much appreciated.
Hayden
'90 Eunos Roadster V-SPEC. Tan Leather, British Racing Green.
timk
Postby timk » Mon Jul 02, 2007 11:40 pm
Hi Hayden,
I just removed the black plastic from around the headlight (4 screws) which allowed access to the front screws. After removing the front ones I could lift out the whole unit and remove the H4 bulb from the back. Does your bulb not lift out at all?
A replacement H4 bulb shouldn't be more than $10.
Tim
Fuzzlet
Postby Fuzzlet » Mon Jul 02, 2007 11:40 pm
Hella make a complete replacement set for them, and it includes bulbs
Juffa
Postby Juffa » Tue Jul 03, 2007 10:14 am
As fuzzlet mentioned Hella make a 7 inch replacement headlight kit, including H4 bulbs. You will notice a huge improvement over your sealed beams. The kit is around $110. Most car part stores should be able to get you the kit. If you buy the kit you can quite easily change your bulbs if they blow, or you want an upgrade. An alternative is to buy a set from a wreckers. 7 Inch headlights were standard on many cars, and therefore should not be hard to find. Just remember on most cars the lights would have been subject to stone chips and general wear and tear, and so the light output can be affected. Not so much of a problem with pop up headlights.
When fitting ensure you put the headlight on correct side as the light pattern is different between left and right to ensure you are not blinding on coming drivers.
J
lowmiata
Postby lowmiata » Tue Jul 03, 2007 10:32 am
I havn't had a search for my old post as it would have been a while ago
but for what its worth you can get cyrystal look 7\"round lenses for 36 bucks each @ autobarn or similar places
and then you just need the glob
i'll do a search now and see if i can find it
EVI15 1998 to 2008
lowmiata
Postby lowmiata » Tue Jul 03, 2007 10:39 am
the bling of lights
the difference is amazing
EVI15 1998 to 2008
timk
Postby timk » Tue Jul 03, 2007 11:21 am
Will the Hella kit or those bling ones improve the Australian delivered lights too? My low beams are REALLY ordinary, I'd consider them dangerous.
lowmiata
Postby lowmiata » Tue Jul 03, 2007 2:31 pm
saboteur wrote:Will the Hella kit or those bling ones improve the Australian delivered lights too? My low beams are REALLY ordinary, I'd consider them dangerous.
yep mine was aus delivered and the difference is amazing
EVI15 1998 to 2008
green_comet
Car Detailing Guru
Postby green_comet » Wed Jul 04, 2007 12:49 am
Yeah they make a huge difference.. I didnt get the bling ones like lowmiata, as the backing is plastic. I wanted metal backing as im running 90w low beams, with 100w high beams. The bulbs tend to get very hot, and i didnt want anything melting on me.. :?
adamjp
Postby adamjp » Wed Jul 04, 2007 9:44 am
Cibie do a 7in reflector.
If you think the Hella is good, try the Cibie - it's better. :D
7in was the popular size for 4WD (Patrol, LandCrusher, etc.) for many years. Thet is why there are some very good replacements out there.
Adam
timk
Postby timk » Wed Jul 04, 2007 11:36 am
green_comet wrote:Yeah they make a huge difference.. I didnt get the bling ones like lowmiata, as the backing is plastic. I wanted metal backing as im running 90w low beams, with 100w high beams. The bulbs tend to get very hot, and i didnt want anything melting on me.. :?
So did you get the Cibie or Hella ones? It's nice to know I don't have to put up with the standard lights. 8)
Sorry Shadow for totally stealing your thread! :lol:
Shadow
Postby Shadow » Fri Jul 06, 2007 11:00 am
well i did a change at lunch time yesterday. since i had to do a bit of driving last night i bit the bullet and grabbed some from autobarn.
their nardi ones, not the best or quite what i was after but still a hell of an improvment on what i had (even when i did have two lights). cost around the $100 mark.
i might upgrade them again to something i actually want/like later on but for the momment they do the job.
and definatly not a shmick looking as lowmiata's.
thanks all.
Hayden
Lucky_Luke
Postby Lucky_Luke » Fri Jul 06, 2007 11:26 am
lowmiata wrote:I havn't had a search for my old post as it would have been a while ago
but for what its worth you can get cyrystal look 7"round lenses for 36 bucks each @ autobarn or similar places
I wouldnt mind getting some these too.. have you got any part numbers lowmiata??? :D
L.
lowmiata
Postby lowmiata » Fri Jul 06, 2007 7:46 pm
L.
there was in my old post I searhed for it the other day and couldn't get anything?
dunno how long ago it was I think there may have been a forum upgrade since then!
EVI15 1998 to 2008
Fuzzlet
Postby Fuzzlet » Sat Jul 07, 2007 2:22 pm
Damn those crystal look ones are almost tempting me to ditch the low profile lights and go back to normal...
Users browsing this forum: No registered users and 45 guests
