LED Headlights - How effective are they?
Postby Hammer » Fri Jun 29, 2007 1:14 pm
Need advice....
How effective are LED globes if used as a hi-beam headlight on an NB8B - replacing the standard halogen globes?
I frequently travel late at night to Port Stephens, and I seriouly need brighter hi-beams. The standard hi-beam on my 5 are practically useless.
I found a pair of HB3 1W LED globes. It a simple globe replacement. No other change to the orignial NB8B headlight will be made.
Has anyone used LED globes for a headlight?
Caffeine
Re: LED Headlights - How effective are they?
Postby Caffeine » Fri Jun 29, 2007 1:33 pm
Hammer wrote:Need advice....
1W will be pretty pitiful.
I have a 12W LED on my bike, and that's the brightest LED technology available today, I wouldn't even consider it for the low beams on my car.
Garry
Postby Garry » Fri Jun 29, 2007 1:42 pm
With respect have you thought about getting your eyes tested? I have Phillips \"plus 50' bulbs in my low beam and \"plus 30\" in my high beams and I find the light output on my car to be excellent. Even on deserted country roads.
ducktape69
Postby ducktape69 » Fri Jun 29, 2007 1:55 pm
i find the low and high beams on my nb8b to be excellent.
they both beam light in appropriate places. maybe u need to adjust them?
the fog lights also add that little bit of light to the sides...especially useful for twisty's where a lot of blind corners come into play...
Postby Hammer » Fri Jun 29, 2007 3:33 pm
Garry wrote:With respect have you thought about getting your eyes tested? I have Phillips "plus 50' bulbs in my low beam and "plus 30" in my high beams and I find the light output on my car to be excellent. Even on deserted country roads.
Eyes are fine. 20/20 vision.
But compared to my GF's company car - Toyota Aurion, my hi-beam are pityful. Although I've recently adjusted the alignment of the headlights of my NB8B, which I have to say were aimed way too low before. Hopefully this will fix the problem.
But thanks Caffeine. I thought just as much that 1W will be useless. And having read the eBay item again, it's aimed at fog lights.
Postby manga_blue » Fri Jun 29, 2007 7:23 pm
I asked about LEDs to replace 12V downlights in the house. Was told that they now have an effective range of about 1 metre unless you buy the $90 model which just gives enough light to read at table level. Can't imagine that'd do much for your driving experience if you put them in a car.
Caffeine
Postby Caffeine » Fri Jun 29, 2007 8:18 pm
manga_blue wrote:I asked about LEDs to replace 12V downlights in the house. Was told that they now have an effective range of about 1 metre unless you buy the $90 model which just gives enough light to read at table level. Can't imagine that'd do much for your driving experience if you put them in a car.
The $90 one would be the osram dragon puck, it's 3.6W (actually 3x1.2W in a housing.
The expense with them is the housing, the actual golden dragon LED's are only ~$4 each
They are about 38lm per watt, which is pretty good. Fortunately Osram have managed to scale up the power handling for the OSTAR series, which is basically 4 or 6 newer generation golden dragons on a common die. These produce again 38lm per watt at 350mA, but can handle up to 1A continuous. This (in the 6 chip version) will produce anywhere between 410 and 820 lumens depending on the intensity binning.
I have a couple of the 6 chip OSTARs and some of the 4 chip ones too, they are awesomely bright for an LED (~200000lux at 10cm with a +/-9 degree reflector) their performance is about as good as a 30W -50W halogen.
That's what I have on the bike, and it's pretty damned bright, but not enough to replace a low beam MX5 headlight, let alone a high beam one.
rjastra2
Postby rjastra2 » Sat Jun 30, 2007 10:12 am
People should have a look at the LExus (US) site
The LS Hybrid has LED low beam headlights :)
Postby Okibi » Sat Jun 30, 2007 7:51 pm
I think some propper Xenon lights would be the go, or a roll bar/nudge bar and some of these babys.. :lol:
Garry
Postby Garry » Tue Jul 03, 2007 1:42 pm
I've read good reports about these babies. The only problem they seem to have is a shorter life than regular bulbs, but that shouldn't be a problem if they are only used in the high beam housings.
http://www.hirheadlights.com/
Postby Hammer » Tue Jul 03, 2007 3:26 pm
Garry wrote:I've read good reports about these babies. The only problem they seem to have is a shorter life than regular bulbs, but that shouldn't be a problem if they are only used in the high beam housings.
Hmmmmm, veeeery interesting. Nice find Garry. I just need to find one that sells them locally.
Image Image
Postby Hammer » Tue Jul 03, 2007 6:40 pm
Sorted! Found them in eBay.
Ordered a couple of 9005 type for the Hi-beam. I'll let you know how they perform and compare with the halogen when they arrive.
Including P&H, total cost was AU$73.50 - gotta love how the Aussie dollar is performing at the moment. :mrgreen:
Garry
Postby Garry » Wed Jul 04, 2007 10:06 am
Looking forward to your thoughts. When I was looking at them the exchange rate wasn't as good and I thought they were too expensive.
Postby Hammer » Thu Jul 12, 2007 3:56 pm
Garry wrote:Looking forward to your thoughts. When I was looking at them the exchange rate wasn't as good and I thought they were too expensive.
Finally got the bulbs ordered from the US. Only took about a week to get there.
Compared to a normal halogen with the same wattage, they are brighter. I would say, they are comparible to the Phillips halogen globes that cost about $70-$90 a pair.
However, they do not emit white light as described. Kelvin wise, the site says, it projects about 3200 kelvin, but I don't see it any whiter than a normal halogen. And compared to my HID lights, look positively amber.
So was it worth the $75 I paid for? Not sure....but I'm leaning towards the negative.
PS. I'll post photos of my 5 to show the difference between the halogen, HIR and the HID lights shortly.
rjastra2
Postby rjastra2 » Thu Aug 02, 2007 10:34 am
So, whats the feedback on the new lights?
