HELP!!! NA Pop-up headlight NOT poping up!
Mr Starlet
Postby Mr Starlet » Wed Mar 07, 2007 10:33 am
Hey All
What does it mean when my pop-up headlight won't pop up unless I use the button below the hazard?
Any pointers would be much appreciated.
Minh
kitkat
Postby kitkat » Wed Mar 07, 2007 10:45 am
fuse?
Do the lights turn on?
Mr Starlet
Postby Mr Starlet » Wed Mar 07, 2007 11:12 am
kitkat wrote:fuse?
Lights goes on but not poping up, is there a dedicated fuse for poping the light up?
JBT
Postby JBT » Wed Mar 07, 2007 12:02 pm
Possibilities:
1. Retractable headlight relay is inoperative (but don't ask me where it is :? ); or
2. Wire to it is broken/disconnected.
kitkat
Postby kitkat » Wed Mar 07, 2007 12:18 pm
Click the link to view the wiring diagram for the lights.
Hope you can read electrical diagrams :P
http://test.miata.net.au/headlights.jpg
kitkat
Postby kitkat » Wed Mar 07, 2007 12:20 pm
can also have a look at...
http://test.miata.net.au/headlights1.jpg
Edit: Mr Starlet... have i geven you a copy of the workshop manual yet? There is a complete trouble shooting process in it. Im going through it now ill post if i find anything.
Mr Starlet
Postby Mr Starlet » Wed Mar 07, 2007 12:31 pm
kitkat wrote:can also have a look at...
Yep going through the manual now...it's pain looking through that PDF
kitkat
Postby kitkat » Wed Mar 07, 2007 12:41 pm
its not that bad :P
Use the bookmarks on the left and its a breeze.
JBT
Postby JBT » Wed Mar 07, 2007 3:03 pm
Mr Starlet wrote:Yep going through the manual now...it's pain looking through that PDF
Save your energy and find the retractable headlight relay. Hint: it's not in the engine bay where they say it is for the US market cars.
broady
Postby broady » Wed Mar 07, 2007 7:32 pm
Also consider the difference if one is popping up and the other isnt, its probably a fault with the motor itself then
Mr Starlet
Postby Mr Starlet » Sun Mar 11, 2007 2:25 pm
So where would I find this relay? under the driverside where close the fuse box?
JBT
Postby JBT » Sun Mar 11, 2007 6:11 pm
That's the whole problem...I don't know where it is but I know a couple of places it isn't.
I thiiiinnk it may be up under the dash on the driver's side but not with the other relays that are around the fuse box area.
Wire colours are:
red/green
white/black
black
red/yellow
white/red
Russellb
RIP Nov 2014
Postby Russellb » Sun Mar 11, 2007 7:48 pm
Check that the Tail lights work. The tail light fuse operates the pop up Relay. the button on the dash bypasses the relay ( well on the NA 6 it does)
The hidden relay is under the dash on the drivers side, near the steering column, remove the plastic panel under the column to gain access.
Hope this helps :)
My ClubmanRebuild
MX5 SE Rally car is HERE :)
JBT
Postby JBT » Sun Mar 11, 2007 8:50 pm
My understanding is that power for the operating side of the retractor relay comes through the \"head\" fuse via the headlight relay. The Motor power then come via the centre console override button.
Check this diagram
Russellb
RIP Nov 2014
Postby Russellb » Sun Mar 11, 2007 9:22 pm
That is not the same wiring diagram I have. I have the Mazda Australia
book . for both the 89 NA and the 95 NA, there is a differance for the 2 models.
will take a Pic of the pages and post them up tomorrow
My ClubmanRebuild
