NA6 stopped dead. Electrical issues.
StanTheMan
Postby StanTheMan » Wed Feb 28, 2007 9:51 pm
Patchy's stopped dead.
Driving along very merryly this morning.....stop dead.
stalled....wouln't start again.
so the basics......
Its got plenty of battery power.
Its got 1/2 a tank of petrol.
Its got spark.
Not sure about petrol.
so assuming its got no petrol....why not.
so since its been so long since i've had this sort of trouble....I got no idear where to start. :lol: :oops:
I suppose i should check all the fuses first..... which fuses?
any help is appreciated.
NMX516
Postby NMX516 » Wed Feb 28, 2007 9:55 pm
phew, where to start....
Does the fuel pump work??
Check EFI relay, fuel pump relay and fuse, ECU fuse, crank angle sensor... Those would be my first checks STM. Edit: in no particular order, do the easy ones first :)
AJ
Postby AJ » Wed Feb 28, 2007 9:57 pm
:shock: Oli put the mockers onya mate :lol:
wind on it for a few secs, then pull a plug & see if it's wet............just to make sure you have fuel at the bit that's sposed to go bang.
XMX5 Rogues
kitkat
Postby kitkat » Wed Feb 28, 2007 10:00 pm
Hmm... find out whether its fuel or a spark problem. Pull of a plug and look for an arc when trying o crank it over.
If there is spark move onto fuel.... pull another plug and check if its wet.
If there both good then im out of ideas :|
StanTheMan
Postby StanTheMan » Wed Feb 28, 2007 10:03 pm
Ok so where exactly are those located
I know there is a fuse box in the engine bay. across the other side are some relays. One of which I'm sure belongs to the cooling fan. There is also a small fues box under the dash on the drivers side......but that may be for the alarm & fuel cut off system installed.
I would dread if it had anything to do with the mess under the dashboard.// Its been butchered by some alarm install.......
but first things first.
StanTheMan
Postby StanTheMan » Wed Feb 28, 2007 10:04 pm
kitkat wrote:Hmm... find out whether its fuel or a spark problem. Pull of a plug and look for an arc when trying o crank it over.
done that...its got spark.
havent pulled another spark plug out.
not sure if the fuel pump is working.
lowmiata
Postby lowmiata » Wed Feb 28, 2007 10:06 pm
is the fuel pump cming on when you tur the key to the 'on' point?
should beable to hear the it start it runs for about 15 seconds
if you are in a quite place you can put your hand on the rocker under the door and feel the car hum when the pump runs
if it doesn't run you can ground the pump so it runs and try and start it then this will prove problem with fuel pump!
was it a straight cut off or did it cough a little then stp?
EVI15 1998 to 2008
bigdog
King of the kennel
Postby bigdog » Wed Feb 28, 2007 10:07 pm
Did you get the car home Stefan, or is it stranded outside some sleazy bar on the North Side? :P If you have fuel and power check the main ignition relay - about $35 from Mazda for the NB one. I carry a spare for mine after Dave had two fail... Otherwise follow the sage advice of the rest of the guys here who know more than me about these things...
StanTheMan
Postby StanTheMan » Wed Feb 28, 2007 10:14 pm
lowmiata wrote:is the fuel pump cming on when you tur the key to the 'on' point?
cant recall exactly....I stalled it. Or at least i thought i stalled it. then when it didn't start straight away so i thought i had drowned it. but it never started again.
There seems to be no hiss....... so I'll check that out again.....maybe now.
Big Dog....Its about 10min walk away from Home in a safe street.
AJ
Postby AJ » Wed Feb 28, 2007 10:17 pm
*now has an image of stan galloping up & down the street after refreshing this page* :lol:
sorry mate, it's probly not funny for you atm :frown:
XMX5 Rogues
bigdog
King of the kennel
Postby bigdog » Wed Feb 28, 2007 10:21 pm
AJ wrote:*now has an image of stan galloping up & down the street after refreshing this page* :lol:
and refilling the bourbon at each stop :mrgreen:
If the plugs are dry after you wind it over a few times then there's no fuel getting through - could be faulty pump, faulty wiring, fuse or blocked filter.
StanTheMan
Postby StanTheMan » Wed Feb 28, 2007 10:22 pm
AJ......it is funny. as its been sooo long that i've had any of that kind of trouble. best way to deal with it is to have a chuckle. Plus in the end.....i'll be the winner anyway as i'm getting plenty of good help I'm also sure its something very simple.
bigdog
King of the kennel
Postby bigdog » Wed Feb 28, 2007 10:27 pm
Could also be embarrassment - maybe Patchy is tired of running around half naked and is hiding till you come up with a nice red coat :lol:
ampz
Postby ampz » Wed Feb 28, 2007 10:45 pm
Umm... has it got fuel in the tank? :mrgreen:
(Sorry Boags)
Huh?
JSE
Postby JSE » Wed Feb 28, 2007 10:45 pm
Check your Main Relay for the ignition...this is exactly what happened to my car Stan. Mania fixed it for $50...even though towing there cost me an arm and a leg!
EDIT: just saw what BigDog wrote...Check the Main Relay mate
