AJ wrote:*note for MX5 drivers* if you cut me off, the stebel is about ear level for youse, & it WILL make your ears bleed & your undies go brown![]()
I thought that you had that effect by just talking to someone
*runs and hides behind ffg*
AJ wrote::lol:
got to use it in anger today, after an areswipe in a ute decided it was his god given right to push into a space half the length of his vehicle, gleefully jumped on the stebel, & watched as he jumped far enough to bash his head on the roof lining
cruised a bit further & realised it was getting warm in my airconned cab.......................no aircon, no blower fan......hmmmmmmmmmm.............WTF?.............I used the relay, why would i blow a fuse?![]()
checked it when i got home, & in its infinite wisdom, Isuzu decided to run the windscreen washers, the reverse lights, the blower fan, the horn AND because the aircon isn't allowed to be fitted in Japan, the wise owls that do all these fitments out at Eagle Farm decided that the aircon with its condensor fan should ALSO run off a ....................wait for it..............7.5 amp fuse![]()
chucked a 15 amp in & she's all good now
RawSouth wrote:A possible silly question, and a little on a tangent...
But is it possible to fit, say, a Mercedes horn?
Now those things are loud!
