Subwoofer Installs
CheyneX5
Subwoofer Installs
Postby CheyneX5 » Wed Mar 25, 2009 7:24 pm
Holy Bass! That must have been a nightmare to fit.
What size is it?
90' NA6 - Classic Red
Sean
Subwoofer Installs
Postby Sean » Thu Mar 26, 2009 12:34 am
CheyneX5 wrote:Holy Bass! That must have been a nightmare to fit.
What size is it?
I cannot recall if it was a 10 or 12 inch. (oh and despite how it looks that isn't rust behind it!)
It ended up being too much and we scaled it back to be dríven by a small amp and running higher than usual frequencies through it too, not a typically "good" idea but for the small cabin and high amount of roadnoise it was an acceptable solution for me, kinda tried it cause no-one else had and the tank was out anyway.
greenmac80 wrote:newest sorta car i've worked on and yeah bit edgy about pulling it apart!!
but def will be going with the 2 8inch drivers!!
If you get stuck let us know, pretty sure I would have more detailed pics somewhere.
I still think the two 8 inch set-up is the way to go, having said that Benny's SP sounded superb when I heard it a few years back and it has a neat boot install. FWIW I rack up ten hours in a laaaarge car once or twice a month at the moment, no modifications to the factory fitted premium sound package and it is exceptionally good, sub bass is via just two 8 inch woofers fitted to the parcel shelf, so again, I reackon that's the trick in an MX5, even keep the carpet uncut to hit the install.
Subwoofer Installs
Postby Jeo » Thu Mar 26, 2009 5:07 pm
Can't say specifically about that install, but mine in the same place didn't need any cutting. Just the unbolting of a metal cover.
Sean
Subwoofer Installs
Postby Sean » Thu Mar 26, 2009 6:45 pm
Jeo wrote:Can't say specifically about that install, but mine in the same place didn't need any cutting. Just the unbolting of a metal cover.
Definately not in the same place then.
I watched as the nibblers cut away at the metal and the new support was welded in!
Subwoofer Installs
Postby Jeo » Fri Mar 27, 2009 8:50 pm
greenmac80 wrote:so as for 8" drivers wat are there i've done a search and pioneer keeps coming up but i'm not a fan!! also i think $200 for an 8" is way to exxy!
Each or as a pair? Either way you don't want to know what my ID8 was worth...
As for research, go to a car audio store and have a listen to a couple of different sets. Trust your ears, not interweb fourms.
Sean wrote:Definately not in the same place then.
Hmmm, maybe thats why I was encouraged to go with the 8"
Sean
Subwoofer Installs
Postby Sean » Sun Mar 29, 2009 2:56 pm
It's likely.
The 8s will easily fit in the removable alum covers, and they probably provide a more balanced sound too.
Clearly the picture shows I was young and only interested in doof at the time.
muzzy66
Subwoofer Installs
Postby muzzy66 » Mon Apr 06, 2009 8:59 pm
Just curious, when you guys do the bigger scale boot installs, what do you do with the spare tyre in the NA MX5's?
I'm doing a high end competition install in the next couple of months, and I've found a way to get around the spare tyre (by simply installing around it) but at first I was trying to relocate it somewhere and couldn't find anywhere to move it to.
In some of these pics it seems like the tyre isn't there at all, so just wondering if people have just removed it completely (is that legal?) or somehow relocated it?
No matter how you tune the sub in the cabin, if you wanna play your music loud like most people do you wont be able to stand it. The sub has to stand out a little bit, and that constant bass from the cone would drive you insanse.
Not true at all.
If you design the system for sound quality and tune the sub accordingly (so it's at the same volume as your speakers) then the sub won't drive you insane at all. Human hearing is more sentitive in midrange and high frequencies, we 100dB @ 2khz is actually much, much harsher to our ears then 100dB @ 1000hz.
Car
2004 Alfa Romeo 147 GTA
Audio
Source: Clarion HX-D2
Speakers: Focal 165WRC
Amp: Zapco Reference 350.2
Sub: DLS Nordica 10i
Amp: Helix H1000
Sean
Subwoofer Installs
Postby Sean » Mon Apr 06, 2009 9:39 pm
I got rid of my spare all together and just kept one of those "tyre in a can" things in the glove box.
There have been people who managed to mount a full sized spare wheel under the boot, I'm pretty sure there were details on miata.net
muzzy66
Subwoofer Installs
Postby muzzy66 » Tue Apr 07, 2009 9:32 pm
Sean wrote:I got rid of my spare all together and just kept one of those "tyre in a can" things in the glove box.
That's the type of thing I had in mind - is it legal though?
I heard / read somewhere that those kits are only legal for cars that came from the factory without a spare, but I haven't been able to confirm the precise laws on it.
I'd like to get rid of the spare (it'll be useless when I change my rims anyway) but that law continues to bug me. Last thing I want is to get pulled over and defected!
Car
Audio
Amp: Helix H1000
Sean
Subwoofer Installs
Postby Sean » Tue Apr 07, 2009 10:10 pm
It's an interesting question and one that I cannot answer with conviction. I had my car passed through rego thrww years in a row with no spare, but that doesn't mean a lot. I also got it passed NSW enginners and the car was never defected despite being pulled over a few times.
I know it's a defect to replace run-on-flats with normal tyres unless you add a spare, although if you can get an enginner to approve it with regard to teh relevant wheel and tyre size ADR you should be fine.
Subwoofer Installs
Postby Jeo » Tue Apr 07, 2009 11:21 pm
Don't quote me but I belive the law says that you are free to remove your spare. If you keep it you must however keep it in good condition, pumped up, etc.
I know Trader relocated his spare under the car to free up space. You could try shooting him a pm.
muzzy66
Subwoofer Installs
Postby muzzy66 » Fri Apr 10, 2009 10:37 pm
Thanks for the info guys, I'll look into it once my uni assessments calm down a little :)
Car
Audio
Amp: Helix H1000
