Thanks Lokiel for your detailed and educational answer, much appreciated!
Obviously a software guru!
I got a volts gauge up on TS and it reckons 13.1 volts, it pretty much stays put, you can turn lights on, fans and so on and the regulator keeps it firmly planted! If you kill the engine then it reckons 11.8 volts. So yes the voltage monitoring does work. I measured the voltage at the injector 1, measured 13.83 volts running, with a fluke metre. I figure this is close enough because I was measuring to the engine block for the GND lead. I figure there would be some voltage drop across the injector switch wire and across the output IGBT or FET (circa 0.6 volts). So 13.83 - 0.6 -0.1 = 13.11 estimated volts at the injector solenoid, which is what the ECU is reading by lucky coincidence! I adjusted the ADC and it calibrated the on screen volt meter.
However for reasons outlined above regarding voltage drop in the return path I reset it to the default which was 19.7 IIRC. I guess the correct way to measure the injector voltage at the injector would be with an oscilloscope which sadly, as I've retired I don't have access to anymore. Changing the ADC for scaling certainly leaned the AFR out at idle a lot!
I'm about to stick some new FF640 injectors in it, so decided to do a bit of research before putting them in.
