Megasquirt owners thread
StanTheMan
Re: Megasquirt owners thread
Postby StanTheMan » Tue Apr 11, 2017 2:56 pm
Red_Bullet wrote:Injector Dead Time. (latency)
I've been having problems with hot start which got me researching injector dead time. I'm running RX-8 yellow injectors 440 cc. Part number 195500-4450.
Anyway I came across some info from the rotary people regarding these injectors.
6.5 Volts 2.866ms
7.75 volts 1.901ms
9 volts 1.409ms
10.25 volts 1.095ms
11.5 volts .821ms
12.75 volts .660ms
14 volts .510ms
15.25 volts .411ms
16.5 volts .287ms
Doing some maths reveals
At 13.2 volts the deadtime is 0.6ms
which in megatune converts to a dead time table table of:
7.75 volts 317%
10.25 volts 182.5%
11.5 volts 137%
12.75 volts 110%
13.2 volts 100%
14 volts 85%
15.25 volts 68.5%
16.5 volts 47.8%
Going to load up these dead times and will report back results. I note that at 13.2 volts the deadtime is 0.6ms, which is a lot less than the Tunerstudio default of 1.0 ms
how did you go with that Red Bullet?
Received the Rx8 Injectors today.
Dead times are anywhere between 0.6-1.0 researching on the net
its going into a MS2 PnP the assumption that
the Battery Voltage correction is Dead time/voltage
If was to set the dead time around 0.8ms that would make the correction at 0.060ms ?
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Tue Apr 11, 2017 5:42 pm
I tried those settings briefly but was too far down the road with my tune anyway. It was ages ago but I do recall it running really rich at idle (I think). Couldn't be bothered with investing more time in the low duty cycle area of the tune so I just returned to my original settings for dead time.
My hot start issues were related to too much fuel during hot start. Leaned that out and fixed my hot start issues.
If I was tuning from new I would be happy to give those dead times a go.
Red_Bullet
Postby Red_Bullet » Tue Apr 11, 2017 8:11 pm
Correction to above^^^^^
Using the modified Dead time table made it run LEAN at the low duty cycle area. I couldn't be bothered fiddling with it as detailed above as it was already dialled in. So I went back to original table.
StanTheMan
Postby StanTheMan » Tue Apr 11, 2017 8:25 pm
My idle just went super rich.....
but it starts bewtyfully.
My old injectors were totally flocked. it runs sooo much smoother OMG!!!!!
Postby Lokiel » Fri Apr 21, 2017 9:06 pm
I'm trying to get my Android MSTrackIt App running on MS2s (currently running on MS3s) and StanTheMan has been assisting me with this (see http://mx5cartalk.com/forum/viewtopic.php?f=81&t=74657).
On the MS3, the mainController.ini file defines the vehicle speed in variable "vss1_ms_1", Vehicle Speed Sensor 1 in metres per second, and I use that to retrieve the vehicle speed.
Scanning through the MS2's mainController.ini file I can't see anything that looks like vehicle speed in the [Datalog] and [OutputChannels] sections.
How is speed retrieved from the MS2?
Is it calculated from multiple MS2 values and if so, which ones?
Any help appreciated.
Postby Lokiel » Fri Apr 21, 2017 9:14 pm
Just did a search on http://www.msextra.com for this.
jsmcortina's response helped clarify this http://www.msextra.com/forums/viewtopic.php?f=101&t=61148:
"There is no speed-sensor function in MS2. You need MS3 for that.
Analogue inputs can be datalogged. See section 4.10 in the Setting Up Manual http://www.msextra.com/doc/pdf/html/Megasquirt2_Setting_Up-3.4.pdf/Megasquirt2_Setting_Up-3.4-82.html "
Now I love my MS3 even more!
StanTheMan
Postby StanTheMan » Fri Apr 21, 2017 9:18 pm
Sent from my SM-G935F using Tapatalk
S2-13BT
Postby S2-13BT » Sat May 27, 2017 12:28 pm
I'm considering getting MS'd as a step towards eventual forced induction of my car ('95 NA8 manual). What I'd like to do is similar to above though, and run E85 while N/A for awhile.
On the flip side, my car is budget oriented and I'd like to keep it that way... In my head I went straight to the MS3 pro PNP, but maybe I should look at the MS2 based PNP keeping the lower cost in mind. Am I making a mistake, or as I expect the MS2 is going to do everything I need and be awesome.
Oh, I'd like to go plug and play, because I'm not an electronics guy and my soldering skills aren't great! :oops:
Any advice?
Postby Lokiel » Sat May 27, 2017 2:39 pm
S2-13BT wrote:I'm considering getting MS'd as a step towards eventual forced induction of my car ('95 NA8 manual). What I'd like to do is similar to above though, and run E85 while N/A for awhile.
Any advice?
Yes the MS2 is cheaper but it's also about 10 years old now.
StanTheMan
Postby StanTheMan » Sat May 27, 2017 3:18 pm
E85 is nice.....getting tired of constantly filling up.
Most of my stuff is slow peak hr crawl with the dramatic cams idling on 65 Mpa .....sucking it in.
The Flex fuel sensor is a must for me.
MS3 does it much better.
Getting my head around the flex fuel sensor..MS2 PnP...I thought I had it all worked out with the table switching. But a have a sneaking suspicion it doesn't actually work that way.
S2-13BT
Postby S2-13BT » Sat May 27, 2017 4:28 pm
OK, sounds like it's worth spending a bit extra and going with the MS3 based ECU.
StanTheMan wrote:E85 is nice.....getting tired of constantly filling up.
I understand. I used my SG Forester as a daily on E85 for about 12 months... Basically became buddies with the guys down at United. :lol:
S2-13BT
Postby S2-13BT » Thu Jun 22, 2017 5:02 pm
Does anyone know of tuners experienced with MS in the Canberra region? Perhaps the southern areas of Sydney too if need be.
Thanks.
greenMachine
Postby greenMachine » Thu Jun 22, 2017 6:32 pm
S2-13BT wrote:Does anyone know of tuners experienced with MS in the Canberra region? Perhaps the southern areas of Sydney too if need be.
Thanks.
Short answer - No.
I use Eddie at Autotech in Hume for the racecar, but that is a PS1000, and I will be asking him if does them. If I get a MS it will be through Dann and he will tune it, but cold start is not something that can be reliably done in Newcastle for Canberra's -6 to -8 winter mornings. At least that has been my experience over the years with Sydney tuners.
There may be a MS in my future, so I am really interested in what you come up with.
Now, if you will excuse me, I better get on with reading this thread :wink: .
:mrgreen:
S2-13BT
Postby S2-13BT » Fri Jun 23, 2017 7:31 pm
I had my Forester remote tuned for E85 and I had to sort out cold start myself. Wasn't too difficult. Literally just add more fuel (using coolant temp compensation tables) till it starts reliably. I had no troubles starting the car on the coldest morning.
Maybe there's a good remote tuner available somewhere?
Red_Bullet
Postby Red_Bullet » Fri Jun 23, 2017 8:18 pm
There is plenty of info on here, more on Miata Turbo. Load up some of the more sensible AFR tables, sensible Timing tables then use auto-tune. Read the megasquirt manual and follow it when setting up. There is a fair bit to it. Plenty to learn if you find that kind of stuff interesting and you have the time to learn.
I'm happy to share AFR and timing table with you. (98 fuel only)
Otherwise let Dann do it.
